Using this option will restore all of the settings in the Router to the factory (default) settings. It is recommended that you back up your settings before you restore all of the defaults.
1. Click the "Restore Defaults" button.
2. When the message appears, Click "OK".
3. The following message will appear. Restoring the defaults includes restarting the Router. It can take up to 60 seconds. It is important not to turn the power to the Router off during the restart.
4. A 60-second countdown will appear on the screen. When the countdown reaches zero, the Router's defaults will be restored. The Router home page should appear automatically. If it does not, type in the Router's address (default = 192.168.2.1) into the navigation bar of your browser.
From here you can reset your WPA Passphrase. Hope this helps...
Wireless Router and WiFi processes: Belkin Router □ Cannot disable or disconnect the...
(More)
Wireless Router and WiFi processes: Belkin Router □ Cannot disable or disconnect the wireless connection by hitting the disable button □ To disable you have to go to the task manager and end the task □ Sometimes the router does not disengage or disconnect even after the computer is cut off (light stays on) □ After disabling the WiFi connection it will not enable again. When trying to enable the error message comes up ? Connection Failed? ..Can only be enable again by shutting down the computer entirely and restarting again. □ Have to unplug electrical connection to disable the router
Hi i have a belkin wireless g plus mino usb network adaptor running windows XP the computor finds...
(More)
Hi i have a belkin wireless g plus mino usb network adaptor running windows XP the computor finds the devise but will not install it i have downloaded the drivers from the net but cannot find the softwhere can you help please
