Washing Machines
Problem for Washing Machines
Generic problem for all Washing Machines
Have a hotpoint top loading that A.....
By barb_91 on Nov 02, 2009
Have a hotpoint top loading that A..would not stop filling even unplugged, and B. will not drain/spin. Hence, ended up with a flooded room while I was trying to get the water turned off. Any easy way to empty tub (full of jeans)...What could be wrong that all happeneded at once?
Solution #1
posted on Nov 02, 2009
Not Rated)
GodBlessU
Rank: Wiz  Washing Machines  Expert
Rating: 83%, 233 votes
Hi
If your washer is overfilling, check these:
Water-inlet valve
Water-level switch
Water-inlet valve A defect in the water-inlet valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it. If this occurs, the valve may leak and drip water into the clothes tub. In time, the water may accumulate substantially. If this happens, you need to replace the valve.
Water-level switch A defect--or an obstruction--in the water-level switch may mean that it can't tell the water to shut off. So the machine overflows. This switch senses the water level in the clothes tub. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. You can either clear any obstruction in the tube or replace the water-level switch.
When it doesnt spin or drain...
The drain line is probably clogged. Maybe that a sock or other piece of clothing get between the clothes tub and the outer tub that holds the water. In this case it may then get into the drain hose that's attached to the pump.Remove the hoses from the pump and pull the item out. In case it clean there, check the outer tub port- open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then,try to remove the clothing through the port.
Thanks for contacting fixya.com
Was this helpful?
Yes
No
Popular Solutions for Washing Machines
Questions and Unsolved Problems for Washing Machines
Answer
what washer and dryer to buy
Answer
I'm looking at the Whirlpool WTW6300 or Fisher & Paykel WL26CWI Washers. Which should I buy...
Answer
Maytag washing machine (modelA606) After the load completes its cycle, it starts washing the load... (More)
Answer
kenmore 12502100 washer won't complete rinse cycle. fills with water agitates then stops. hear a... (More)
Answer
Whirlpool Cabrio is flashing a LF code and all the lights on the machine are flashing at the same... (More)
Describe your Washing Machines problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Washing Machine Experts
Top Washer & Dryer Repairmen
(773) 507-7822
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
What is this?
Select
close
Add to My Products
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
Step 1: Select a category & subcategory
Step 2: Select a product and click on add
I can't find my product
select
close
Success!
Add another product
Close
close
Save This Product
Enter your email address
We will not share your email. Privacy Policy
I agree to the FixYa Terms of Use
Send to friends
Send to: (e.g. Julie@email.com)
(Separate email adresses with commas)
Your name:
Your email address:
Message:
