Coleman Mach III Air Conditioner
Problem for Coleman Mach III Air Conditioner
Coleman roof top a/c, is the heat controlled by thermostat
By whatgrade on Nov 02, 2009
do the new coleman a/c's heat strip work like the old ones, they were controlled by thermostat. On some other manufacturers models, the heat is either on or off. No way to control the heat by thermostat. Our old one was a "set it and forget it".
Solution #1
posted on Nov 02, 2009
Not Rated)
breeze_ac
Rank: Guide
Rating: 97%, 3 votes
hi
on the new colman units (trane) the heat is control only from the t-stat.
i will reccomand a programble t-stat for the new unit.
thanks
Was this helpful?
Yes
No
Popular Solutions for Coleman Mach III Air
Questions and Unsolved Problems for Coleman Mach III Air
Do you recommend Coleman Mach III Air Conditioner?
Answer
Answer
installing to volvo 36ft bus need installation requirements for water drainage, electrical and... (More)
Answer
water is entering through unit. i think the previous owner sealed around weep holes. how do i fix or... (More)
Answer
I have a coleman top unit in my travel trailer the wires running from the thermostat are red green... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Coleman Mach III Air...:
Top Air Conditioner Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Air Conditioner Experts
Top Air Conditioner Repair
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
