Question about RCA P52937 52" Rear Projection Television
Difficul to turn on
After you turn off the tv it almost will not come back on. You cannot use the remote and have to spend your time in the floor pushing the channel up button and power button simultaniously until it makes a loud popping sound and then it pops again and the screen comes on. This process is becoming longer and longer and more and more aggrevating@!!!
At one point a tech said the processor would need to be replaced is this the issue now? or what can be done???
HELP please!
  • 373 Answers
If it is making a loud poping, there is a high voltage leak probably and most likely at the high voltage transformer which is the 3 inch square white device with the large red wire coming out of it. With someone turning on the set on someone looking in the back with the back off you will see the arc of high voltage. Also look up under back in further where the tubes are (three) and look for the arc. But is most likely on the transformer. Common problem is the transformer and must be changed by trained person.
Posted on Jan 05, 2008
How to turn off timer
I wouls unplug the TV overnight and see it it resets the timer feature. To pair the remote, you need to know the code and the pairing procedure - most remotes come with a manual or you will need to spend some time on Google.
May 25, 2015 | Televison & Video
I HAVE A 15 YEAR OLD ZENITH 27 INCH TELEVISION (MODEL- SE 2719P). THE ONLY WAY TO TURN IT ON IS WITH THE REMOTE. AFTER THE POWER WENT OUT FOR 20 SECONDS, I TRIED TO TURN THE TV BACK ON & NOTHING...
Yes it is definitely time for a new tv. If you live near a populated area just go on your local craigslist and you can get great used televisions for quite cheap. I have seen nice 36" tv's sell for 50$ and less.
Thank you and good luck,
Lee
Aug 20, 2010 | Zenith Televison & Video
Can only turn power off and on with remote
ur cheap, next time spend more money buy better tv.
Oct 09, 2009 | Mintek DTV-263 26 in. TV/DVD Combo
I'm having difficulities with a RCA entertainment series television. A little while ago my T.V started going crazy. For example, Sometimes when i go to turn it on to change the channel it will say panel...
Best Way reset the set,U right it well reboot itself,before u go to sleep unplug the tv,take out the bateries to remote.Morning,plug in and put the bateris back might reset it self.
Aug 17, 2009 | RCA 32F531T 32" TV
TV will not come on with remote or power button
The following instructions are for the Emerson EWC1303/1903 tv/vcr. That's the closest match I could find to the Spongebob Squarepants 13' TV
If it's actually in Sleep mode, do the following:
TO CANCEL THE SLEEP TIMER
Press the WAKE UP/SLEEP button on the remote
control until “SLEEP TIMER” appears.
To view the time left for sleep timer press the WAKE
UP/SLEEP button twice, then press the MENU button
on the remote control to exit the sleep timer setting
If unsuccessful, try unplugging the TV for 1/2 hour, then plug it in and try turning it back on either manually or with the remote. Either of these should solve your problem. Best of luck to you!
May 08, 2009 | Emerson SpongeBob SquarePants TV
On and off
That hapened to me once and the solution that worked for me was unpluging the TV for about 5 minutes and pluging it back in, you may just need a new remote though.
Jul 28, 2008 | Philips 55PP9352 55" Projection Television
QUESTION ABOUT PROGRAMMING CABLE REMOTE TO T.V
the code for olevia for cox cable is 1610. Hit tv then hold setup till light blinks twice. release setup. enter 1610 and wah lah
Dec 31, 2007 | Olevia LT42HVi 42 in. LCD Television
Remote control problem
Have you tried "One for All" universal remotes?
Jun 10, 2007 | Polaroid 1720-7 Remote Control
RCA P52937 52" Rear Projection Television Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
