Question about HP 33s Calculator
Display The display of my hp 33s doesn't light up. I thought the batter was dead. I replaced the battery and it still doesn't work. I have probably had the calculator for about 2 years. Any ideas?
  • chisle Jan 03, 2008
    I saw some other posts. I pushed the reset button and it now works.
  • 319 Answers
Great to hear!
Thanks!
Posted on Jan 03, 2008
6ya staff
SOURCE:
How to fix a failing display?
There is probably not much you can do except send it for repairs. But I don't think it would be worthwhile to do so.
Aug 19, 2015 | HP 33s Calculator
Samsung s5620 repair
Drained/dead battery
Plug your iPhone into your computer or wall adapter to charge. If it does not charge when connected to either of these, you probably have a dead battery. The battery will need to be replaced with a new one.
Bad display
It is possible that it appears nothing is happening because the display is bad. If the iPhone sounds like it is working properly but nothing is visible, it is possible the display is bad and must be replaced. Unfortunately, the LCD and glass panel are fused together, and must be replaced as one unit.
Bad logic board
If nothing else works, your logic board is probably bad and needs to be replaced.
God bless you
Jun 01, 2013 | Cell Phones
Goldline controls troubleshooting
Plug your iPhone into your computer or wall adapter to charge. If it does not charge when connected to either of these, you probably have a dead battery. The battery will need to be replaced (GSM (AT&T) or CDMA (Verizon)).
Bad display
It is possible that it appears nothing is happening because the display is bad. If the iPhone sounds like it is working properly but nothing is visible, it is possible the display is bad and must be replaced (GSM (AT&T) or CDMA (Verizon)). Unfortunately, the LCD and glass panel are fused together, and must be replaced as one unit.
Bad logic board
If nothing else works, your logic board is probably bad and needs to be replaced (GSM (AT&T) or CDMA (Verizon)).
God bless you
May 24, 2013 | Cell Phones
How do you clear a flashing "MEMORY CLEAR" on my hp 33s? I just changed the batteries.
I'm sorry for the difficulties you're experiencing as the Memory Clear displayed on the Calculator. Please clear the memory by following steps below and check if that helps.
Thanks for understanding. Please let me know if you require any clarifications.
Aug 22, 2011 | HP 33s Calculator
Display screen doesn
I had the same problem here,,,
This was my friend rowing that we received as a "gift" (he wasn't using it anymore) and the LCD display stop working.
Without the user manual, I decided to remove the side panel and by doing so the LCD panel pop out showing the source of the problem...
The AA battery simply felt off inside the case.
So my guess is that either your battery felt off or is dead.
So here're the steps...
1. remove the LCD panel (use a flat screwdriver if needed)
2. if there's no battery, it is probably inside the assembly. You can try to retreive it by removing the 7 screws on one side or simply leave the battery if it's not interfering with the rowing mechanics.
3. if there's a battery, it's probably dead. Change it!
Apr 02, 2010 | RTO Lifespan RW1000 Rowing Machine
My hp 33s puts a comma when ever I want to use the decimal point
Switch them.
  1. Press MODES to display the Modes menu.
  2. Specify the decimal mark by pressing ẗhe dot
Jan 31, 2010 | HP 33s Calculator
My lap top r 4000 light up and fan works but no display could this be the battery I replaced the power supply today
Hook it up to an external monitor, if that works. Might need a new Lcd display or at least an Inverter. May be a pinched wire near the hinge of the lcd display.
Doubt it's a batter problem, plug in the power supply , take out the battery and try.
Oct 16, 2009 | HP Compaq Presario R4000 Notebook
Decimal to fraction on hp 33s
Press left-shift [FDISP] to toggle between decimal and fraction display.
Apr 28, 2009 | HP 33s Calculator
Low battery indicator, even after a new battery
You probably have a dead cell in your replacement battery. Camera batteries have a limited number of charge cycles, and this is not a rare issue with "aged" batteries. Also, when you get a new battery, buy a genuine Canon replacement and not one of the el-cheapo Chinese copies available online. In camera batteries, you really do get the quality and performance you pay for!
Jun 27, 2017 | Canon Photography
HP 33s Calculator Logo
182 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
