If the water in the tub just stays in the tub no matter what,then the water pump is most likely bad.If not ,there is a piece of clothing in the pump,witch has stopped the pump.Check the drain hose also,to make sure that the hose is not restricted with anything,or the hose is not crimped.I hope this answers you question,and if so,please let us know ,thank you.
a couple of things to check, see if one the drain hose it clogged, and two the drain pump is operating properly. if you dont feel comfortable doing these test, call a pro and be safe, spend the money to have it done right then do it yourself and break something that costs a lot more.
My Whirlpool Estate type 111 is leaking from the middle front of the cabinet. There is no...
(More)
My Whirlpool Estate type 111 is leaking from the middle front of the cabinet. There is no particular noise during operation, although the machine could be better balanced on the floor. The drains and connected exterior hose are not the problem. Can you help?
Started a wash cycle, water ran in and then machine stopped and the water is not draining. We have...
(More)
Started a wash cycle, water ran in and then machine stopped and the water is not draining. We have tried stopping and starting numerous times and also opened and closed the top thinking the machine was not sensing the top was closed. Thoughts?
