Question about SanDisk Sansa e260 MP3 Player
Sansa e260 4 Gb player not switching on
Battery was fully charged and after switch it played for 5 minutes. after that it shown some unknown format filesplayer got strucked later player switched off itself ..now it is not switching on
can any body help me out please
  • 758 Answers
Try to ge the latest firmware upgrade for your device...that usually solve the battery problem you are having....
Posted on Jan 03, 2008
Charging
USB Cable Make sure that the USB cable is properly plugged in and use the original cable that came with your player. Try a USB plug o the back of the computer. These plugs have more power available.
Computer in Hibernation mode Make sure the computer isn't entering hibernation or sleep mode while the device is connected. The computer must be ON in order to charge your player. Check you screensaver and power settings.
USB Port 2.0 Make sure the player is connected to a USB 2.0 port (1.1 occasionally causes charging problems).
Battery Make sure the battery is fully charged. It takes approximately 3 hours to fully charge the battery.
Latest firmware Depending on what Sansa player you have, make sure it's up to date with the latest firmware.
AC charger (optional) AC chargers (sold separately) have a 500-1000 milliamp max output, which provides much better charging ability than a USB port. These accessories are available on our online store.
Next try and reset the player. Resetting the player: 1. Slide and hold the Power switch up for approximately 20 seconds. 2. Release the Power switch. 3. To turn the player on, slide the Power switch up then release instantly.
Once it is back working, go to the SanDisk support site and get the updater program and update your firmware.
Jul 15, 2010 | SanDisk Sansa View 8GB MP3 Player - Black
After charging my MP3 player it appears fully charged but it will only play for about an hour and the battery runs down. i have recharged it again, same thing. now what?
The very first time you charge your battery YOU MUST CHARGE IT FULLY!!! If you didn't, that is probably the problem.
Also, even if you charge the player for just a couple of minutes it will APPEAR to have a fully charged battery when it actually doesn't.
Most portable media devices require at least 20 minutes to an hour to fully charge whether the screen shows that it is fully charged or not.
Jun 30, 2010 | SanDisk Sansa e250 MP3 Player
I can't get mines to charge correctly, can you help me?
There is a trick to charging the battery in these small mp3 players. It wont charge if it is turned on, and it won't charges if it's turned off. Here what to do...
1. plug the player into your USB port. or wall charger
2. switch the player on using the mechanical switch (on the side)
3. turn it off by either holding down the play button, or selecting "System" from the menu
4. The screen will go black and the battery will begin charging.
Apr 25, 2010 | SanDisk Sansa c250 (2 GB) MP3 Player...
I need help on my Sansa e250, if I plug it to a computer or if i charge and even just merely turning it on, it just turn's on and off, my cousin who gave me my sansa told me that the battery was just...
Remove the back and check and see if the battery isn't fully connected
I put a folded peace of paper and put it on top of the battery and put the back on.
Usb mode is in settings push center button choose between msc or mtp....
MSC will allow you to see the expansion card mtp won't.....MTP shows you your music2_bing.gif folder in the media folder thats where you put your music plus expansion.....If no usb mode the player is manufactored to be in msc mode make sure your usb 2.0 driver is installedMSC is best reate a music1 folder and put music in there then there is no switching back and forth to mtp msc
Apr 06, 2010 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e260 (4 GB) MP3 Player MP3 and Digital Media i have a e260 sansa mp3. when i plug it into my Answer i have a e260 sansa mp3. when i plug it into my computer it wont charge what should i do
1. plug the payer into your USB port. or wall charger
2. switch thje palyer on using the mechanical switch (on the side)
Jan 30, 2010 | SanDisk Sansa e260 MP3 Player
My son's c250 shuts itself off after a minute.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
-Tha Mp3 Doctor
Apr 02, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Mp3 in as "unknown". Won't play
download Switch by searching for it on google...then you can change the formats of your songs to anything you like and you can change how big the file gets converted to!!!
you can make them pretty small and then you can fit about 2,000 songs on a 2 GB!
hope this helps!
don't worry Switch does not give you spyware1.gif or viruses1.gif.. I checked! :]
this will "clean up" the files you want to put on your sansa...
it really works!! AND ITS FREEEEEE
Feb 17, 2008 | SanDisk Sansa e250 MP3 Player
E260 4gb sansa not turning on
some may be due to low battery power or due to software problem...while charging stop once the charge gets full,...dont overcharge the battery,,,,,,the battery life gets reduced
Jan 03, 2008 | SanDisk Sansa e260 MP3 Player
How Long to Charge??
sandisk recommends 3+ hours for the initial charge and then about 1.5 - 2 hours for after the battery is drained. More information is needed to diagnose this problem. but here is some info. After 45 minutes on the phone with sandisk to get them to send a new battery, they ran me through these troubleshooting steps, hope they help. do one at a time and see if you get a result -Reset device take out battery hold power button for 30 count put battery back in turn device on. -Upgrade firmware Go to website, download firmware update This was the URL at the time of writing this http://sandisk.com/Retail/Default.aspx?CatID=1376 or try http://sandisk.com/Retail/DriverDownloads.aspx Install according to instructions. let the device reboot. -Format memory. turn hold switch on, orange should be visible hold pause/play button and press power. click forward button when the screen comes up. let this run. after reboot flip the hold switch off. then they put me on hold for 10 minutes...
Aug 19, 2007 | SanDisk Sansa c250 (2 GB) MP3 Player...
SanDisk Sansa e260 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
