Front loaders are known for building up mold and the smell.
It’s caused by using liquid detergent which is made from animal fat. Use
powder. And use the minimum amount.
It’s caused by using fabric softener. Dilute it50/50 with water.
It’s caused by the water remaining in the tub between washes. Leave the door
open to allow it to dry. .
Pull the rubber door seal back and clean the mold off .
frigidaire front load washing machine works well bot dose not spin and the timer shuts off at 7 min...
(More)
frigidaire front load washing machine works well bot dose not spin and the timer shuts off at 7 min mark
drum does not move...... I accidently left the drain hose on the machine and the water discharged on...
(More)
drum does not move...... I accidently left the drain hose on the machine and the water discharged on it..... The timer lights and the pump works just the drum I have left a fan on forthe day and blew out the terminals....Should I let it dry for a few days b4 trying it again.
i have a washer H E and the softener compartment doesn't empty anymore. it worked fine since i...
(More)
i have a washer H E and the softener compartment doesn't empty anymore. it worked fine since i bought it and that was almost a year ago
