Question about Toshiba 36AF43 36" TV
My set has deveolped an intermittent high pitch squeal.
Sometimes cycling the power will stop the squeal temporarily but it usually comes back. Is this something that is worth repairing? The TV works fine otherwise.
  • 579 Answers
It always nice when the high-voltage circuit gives you fair warning of impending doom. Have the high-voltage (flyback) transformer replaced now before it fails catastrophically and wipes out other stuff with it. There are other things that could make noise too, same advice applies to them.
Hope ya fix it!
Posted on Jan 03, 2008
5 year old goodmans tv suddenly went off, then intermittent high pitched squealing noises
Check the horizontal output section circuit. It sounds that the LOT {Line Output Transformer} has damaged.
May 11, 2012 | Televison & Video
My GEM GL-1821A Computer monitor has a high pitch squeak that is intermittent in occurrence but sometimes continues for long periods of time. Got any ideas?
A high-pitch squeal is common in CRT TV sets and monitors. I've never run across this in an LCD monitor, but there's a first time for everything. If the sound isn't coming through built-in speakers (if this model has them) and is being caused by the computer, I would suspect the inverter circuitry. This provides power for the backlight, and there are transformers that may have become noisy. Because of their construction, it's possible for them to vibrate internally, and at a frequency that you hear as the high-pitched noise. There isn't a lot you can do to quiet them. When I worked on TV sets, I had mixed success using hot-melt glue to muffle the noise, but usually the only way to completely cure the problem was to replace the parts. It's unlikely you'll find the parts available for a monitor, so all I can suggest is to bear with the noise as long as the monitor is otherwise working properly. Or use this as an excuse to buy a new LCD monitor; they are quite reasonably priced these days.
Feb 16, 2011 | Think Computer GEM 15 Inch LCD BLACK...
Our water softener makes a high pitched squealing noise every 10 min. or so, and then quits for several hours only to start again during the night when we're trying to sleep. Our water softener repairman...
A softener will generally make a high pitch squeal when it is backwashing. This is generally the first cycle in most softeners. It may also do this during the final fast rinse cycle. The second brining cycle takes about an hour. That is why you may have a delay in the squeal. Also I have seen at times when a power surge can force the drive motor into a short backwash. Usually just a few minutes. It may help to put a surge surpressor at the water softener plug.
RJ
Aug 22, 2010 | NRS Fleck 5600 - 64,000 Grain Timer Water...
Loud squealing noise during wash and rinse cycle
The dishwasher make "loud high-pitched squealing sound" during the rinse cycle that is periodic through out the cycle
Nov 24, 2009 | Frigidaire Dishwashers
Toshiba Regza bought 1/28/08 makes squealing noise
It's in the repair shop. I'll write back what the problem was and how much it cost to ship.
Oct 07, 2009 | Toshiba REGZA 47HL167 TV
High Pitch squeal everytime t.v. is turned on. 20min warm-up.
sounds like the switchmode power supply is varrying in frequency ..needs to be checked by qualified tech,,,
Apr 16, 2009 | SNK Magnavox 19MF338B/27 19 in. LCD TV
High pitched squeal on new brakes
Break squeal can be stopped by applying shims or anti-squeal compound to the pads.
Apr 05, 2009 | 2005 Ford Freestar
High pitched squeal
Hi...
Does the squeal come from the TV cabinet or the speaker?
If from the cabinet , it's most likely the Horizontal high-voltage section of the set.
Find someone that's good with hand tools,unplug the set from the wall outlet, let it sit for a good 30 minutes.
have someone open up the back of the set and dust out and vacuum out any dust from inside the set.
Put back together and try it out.
Jan 01, 2009 | Samsung TXN2034F 20" TV
NO PIC HIGH PITCH SQUEAL COMING FORM BACK BOTTEM PART OF TV?
Squealing sound means you have something shorted in high voltage area around FBT on Power/deflection board.UED has replacement boards & Misc Parts for these sets if in stock call them1- 800-648-6657
Dec 20, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
My rca tru flat is NFG
The high-pitched squeal usually indicates that the horizontal drive circuit has failed as a result of a dead line-output transistor. This symptom indicates that the control circuit of the main power supply is trying to over-compensate for a greater than usual secondary current. Certainly, an inspection of the line-output transistor will show that it's most likely dead. Sometimes instead of the squeal you will hear hiccups instead. Focus your attention on the horizontal circuit.
Jan 06, 2008 | RCA TruFlat 27F520T 27" TV
Toshiba 36AF43 36" TV Logo
191 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
