Question about HP Photosmart 2710 All-In-One InkJet Printer
Printer is printing blurry
Everytime i try to copy a paper my copier prints very blurry if is prints at all sometimes it will jam and then stop. what do i do.....
Clean or replace the ink cartridges and select a better print quality from the front panel of the printer.
Posted on Feb 07, 2008
When printing color the paper jams. This does not happen when printing black. How do I stop it from jamming when printing color.
Is that true for both print and copy job ?
Where does the jam happen ?
I am thinking if it is at the paper pickup roller area just as the job starts to print and not midway while printing, check the paper quality; dirty pickup roller; clean cork pad and try job from another tray
Sep 21, 2016 | Konica Minolta magicolor 1680MF -...
Constantly jammed paper when print or copy multiple pages
check if the paper size not match with that sitting in printer sitting and the aplication you use
Dec 09, 2014 | Office Equipment & Supplies
Prints one page double sided, then goes to error light and stops printing
what is the error ?
does it says Paper jam, Open the print cover and remove paper jam..
If this the error repeating then make sure,
1. u r not overfilling the paper tray
2. put the printer on a hard surface (not on a half out surface)
3. from now on be gentle with the paper tray.
4. unplug the printer everytime u r done or atleast overnight.
thanks
Jul 30, 2010 | HP LaserJet 1320 Printer
My canon imageclass mf4270 jams 90% of the time when i try to print. sometimes if i pull out the toner cart several times. it will print.
Hello sir; Check the paper path carefully is there have anything block over there, especial at both end. is the paper jam everytime at same place? cleaning up the roller with alcohol.
Aug 05, 2009 | Canon Office Equipment & Supplies
Everytime I tried to print the paper get jam
Make sure all surfaces are clean and your paper has static electricity removed. you can do this by fanning it over a grounded surface. Check the paper feed rollers to be sure they are clean and have no sticky areas. Be sure no to put too many pages in at a time. Try one page at at time first to test and see if all goes well then proceed to try several sheets, about 10 or 12.
May 03, 2009 | Lexmark X2600 InkJet Printer
Printer says paper jam and stops- but it is not jammed
your description indicates you need to thoroughly check printer for any bit of paper ........rolller too has to be checked so that paper is moving smoothly ......
Feb 02, 2009 | Brother MFC 420CN All-In-One InkJet...
Epson RX500, Paper Jam - printing couldn't start
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button, applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time. Worth a try. I have fixed a number of printers this way saving costly repairs. Bud
Jan 06, 2009 | Epson Stylus RX500 All-In-One InkJet...
Re: Paper Jam
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 02, 2009 | Lexmark X3650 Printer
My printer prints blurry lines!
Try this: make a copy and stop it when it reaches the cartridge ( has to have image on paper) take out paper and look at it, does it have blurry copies? if yes, then the problem is with the cartidge or (worse) the laser printing device ( expensive).
Take a chance and replace the cartridge.  if still there you need to replace the laser unit.
If it does not have blurry copies when you stop it at the drum then check the fuser unit( doubt it ) to see it it has any writing or toner on it.
Good Luck.
Oct 31, 2007 | Office Equipment & Supplies
HP Photosmart 2710 All-In-One InkJet Printer Logo
512 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
