Turned Whirpoll ED22PE off and moved to install new flooring. Put back to previous location, connected water and elect...would not make ice.
Someone said it has a temp sensor and must be 10 deg b4 making ice...so turned back on, lowered temp, it made ice one cycle and now has water and ice splashed on inside of freezer.
Turned off, thawed out, wiped all water out, got water out of ice trays with towels...turned on, waited until temp was stable and abt 5 deg's, turned ice maker on...make one tray of ice...the water line to trays is froze up...it's a half pipe that runs from back of freezer to ice tray...seems it's full of ice and won't let water into trays.
If the water valve is leaking a bit, it will cause freezeup, as will a flow restriction. The 'water splashed inside freezer' sounds like leaky shut-off valve.
Sometimes those 'saddle pirecing' water shutoff valves get restricted, so you are not getting enough pressure.
Also, if you had things disconnected, a little bit of grit may be in the filter or shut-off valve, causing issues.
I would:
a) check the house water pressure, to make sure it's normal
b) check/clean/replace fridge water filter
c) inspect/replace saddle valve and look for kinked water feed line
d) backflush water out of fridge, if possible, and look at clean/inspect/replace water valve.
Although they do make add-on heater kits for water maker feed lines, your issue just sounds like a water flow issue...either a leaky valve or a flow restriction.
I Have a Kitchen aid superba side by side with the water filter in the bottom. Water comes to the...
(More)
I Have a Kitchen aid superba side by side with the water filter in the bottom. Water comes to the cold water outlet but not to the ice maker. I changed the filter but it did not help. The green light outside is on but the red light inside close to the on/off switch is blinking. The switch is on.
Ice is dispensng but water is not. Have never changed filter. Could that be part of the problem....
(More)
Ice is dispensng but water is not. Have never changed filter. Could that be part of the problem. Can't get the filter off.
The refrigerator stoped cooling at night, lowered the tempeture setting still wont cool what could...
(More)
The refrigerator stoped cooling at night, lowered the tempeture setting still wont cool what could be the problem
