Question about Brother MFC-9420CN All-In-One Laser Printer
MFC 9420CN My printer is giving a message to replace opc belt. The only thing that i could find online is for $309.99. I just wanted to double check if this is the product that i need to purchase. I would really appreciate it if you reply as soon as possible. Thank you.
  • 3 more comments
  • Nata8 Jan 03, 2008
    Thank you very much for the fast response. If i wait to replace it, this would not harm the machine correct?
    Thank you. I reset it, and the message to replace the belt is gone. Thanx.
  • Nata8 Feb 01, 2008
    Hi, i have another issue that i can't find in the printer's book. I need to change the station ID: Fax number. The machine is already programmed to show a certain fax number, i want to erase this number. I do not want my fax machine to show any numbers when i send out a fax. I would really appreciate it if you can help me solve this issue as soon as possible. Thank you.
  • Nata8 Feb 04, 2008
    Thank you for the reply and for the information. I really appreciate the fast reply.
  • Mona R?seth
    Mona R?seth Jan 07, 2014
    Pressin 1+7 removed the message - and the printer works fine :-) Thank you!
  • 146 Answers
As far as the OPC belt - don't replace it until you start seeing ghosts and image defects! Reset it by:
Press 1 and 7 at the same time
Press 1 to reset the life counter.
Posted on Jan 03, 2008
  • Brian Bell
    Brian Bell Jan 03, 2008
    I am a certified color copier repair tech and it is commonplace to use comsumables past their life expectancy so long as the print quality is not comprimised. Some units may be reset and others have CRUM chips that must be reflashed or pico fuses which must be replaced to facilitate this. Luckliy your unit can bereset from the control panel. I hope the reset instructions are accurate, I tried to confirm them from another source. If that doesn't work please reply and I will research a further solution.BTW: I ALWAYS disclose to our clients that apart has been refurbished, as charging for a new one would be unethical as well as illegal.
  • Brian Bell
    Brian Bell Feb 03, 2008
    Here is a link to the manuals for that unit. I would like to remind you that not putting the transmit ID information in the header of an outgoing fax is illegal. It is usually not an issue but I wanted you to know that if you didn't already. Let me know if I can be of further assistance.
    http://www.brother-usa.com/manuals/defau...
How do I reset the OPC belt on MFC-9420CN using the menu?
hl-2700" OPC Reset
press GO and "+" at same time
press "+" until OPC BELT appears
press "SET"
that will reset the counter on the expensive OPC.
Since the "MFC-9420CN" is build on the same chassis and engine, the "OPC belt reset for the 9420CN" is as follows:
Oct 20, 2010 | Brother MFC-9420CN All-In-One Laser...
OPC belt is replaced and has 100% life but the OPC
make sure all components are properly seated. also try turning the printer off and waiting a few minutes and turn back on.
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_7148ad2a373711a3
Aug 19, 2009 | Brother MFC-9420CN All-In-One Laser...
MFC-9420CN All-In-One Laser Printer Install OPC belt message
Perhaps your OPC belt is at the end of its life and needs replacing
Apr 07, 2009 | Brother MFC-9420CN All-In-One Laser...
Brother MFC 9420cn printer message
Check to make certain that the OPC belt is both seated correctly and that it is not damaged as even though it may have what you consider to be sufficient life left in it, if damaged, it needs to be replaced.
NO OPC BELT on MFC-9420cn
The opc sensor is not sensing the belt. Open the front cover and remove all the toner trays. You will see the green OPC and the sensor is located in the left upper corner. Also open the top cover and remove the OPC. Clean the sensor with a soft bristle brush. Also make sure the OPC left side is free of toner deposits. This may incorrectly trigger the OPC position sensor. Hope this helps.
Jan 14, 2009 | Brother MFC-9420CN All-In-One Laser...
What is opc belt 2700 CN printer
the opc belt is the optical photo conductor belt in your printer. It is the bright green shiney belt you see when you remove a cartridge. You can access it through the top of your unit. You will see a cover where the paper comes out. Inside there are two green clips that push outward. These release the opc belt.
You can purchase a replacement opc belt from most good stationary and consumable suppliers, however, be ready for a shock. the price of the opc belt is almost as much as the unit is worth.
Dec 12, 2008 | Brother MFC-9420CN All-In-One Laser...
Brother MF 9420CN is asking for troubleshooting and routine maintenance 'unable to print'
Via the control panel (This is a Factory Reset)
  1. Make sure the machine is not operating, then disconnect all the cables from the machine (except power cable).
  2. Press the Menu or Menu/Set key on the control panel.
  3. Press up or down navigation key to select LAN and press Set or Menu/Set.
  4. Press up or down navigation key to select Factory Reset and press Set or Menu/Set.
  5. Press 1 to select "Reset".
  6. Press 1 to select "Yes".
  7. The machine will re-start, re-connect cables once this is complete.
Jan 21, 2008 | Brother MFC-9420CN All-In-One Laser...
MFC-9420 Replace OPC Belt message stays on after replacing belt
Dec 06, 2007 | Brother MFC-9420CN All-In-One Laser...
Brother MFC-9420CN All-In-One Laser Printer Logo
369 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
