The shuffle has been plagued by this error code in the past and it used to mean death. Apple has put an update or "fix" for the error code. http://support.apple.com/kb/HT1238 or if that is not successful, you can do this. Here is a fix that will work in almost 1418 cases. Low-level
format the iPod using a low-level formatting tool. The default format
command in XP will not cut it. You will find plenty of freeware and
trialware tools on the net. Here is one: http://hddguru.com/content/en/software/2006.04.12-HDD-Low-Level-Format-Tool/
Just install the application and run it. Choose your iPod “drive”
and let it do its thing. After the low-level format is complete, run
iTunes and when it prompts you to restore the ipod, do the restore and
your iPod is now good as new !! I hope this helps and good luck! Please remember to vote and leave a testimonial. Thanks.
hi i lost the itunes software bonjour,safari, my ipod cannot connect to itunes.i installed itunes 9...
(More)
hi i lost the itunes software bonjour,safari, my ipod cannot connect to itunes.i installed itunes 9 andits still not connecting or recharging. please can you help me
I broke my second generation shuffle charging dock. I bought a new cable, but itunes doesn't...
(More)
I broke my second generation shuffle charging dock. I bought a new cable, but itunes doesn't acknowledge that its plugged in. no lights on either. Why?
My Ipod Shuffle went through washer and dryer in a pocket. Is does nothing turned on or on charger....
(More)
My Ipod Shuffle went through washer and dryer in a pocket. Is does nothing turned on or on charger. Is there anything I a can do?
