Help Hi i have a Canon iR6800C photocopier at work and we don't have a manual. There are 2 things i would like to find out. 1) is to add a scan address to the favourites buttons, and 2) as i am scanning a lot of documents that start with the name Quote, is there any sort of way i can store this name somewhere so i don't have to type it in everytime i have to scan a document?
  • abaker307 Jan 03, 2008
    Thank you for your reply, it would help me out a get deal. Thanks
  • 146 Answers
Here is a link to an original manual for sale. I am still researching a free manual or other instructions directly related to your question. I will post further as soon as it becomes available.
Posted on Jan 03, 2008
MY canon iR3035 ccd scanner position is faulty..
Re: canon ir 3035 copy not lined up 1/4 inch higher it scans but configuration page i
service mode > copier > adjust > adjust xy > adjust Y input the value from the label on the front cover
This is all I could find. Try adjusting by 1/4 inch. Thank you Santosh
Jun 25, 2016 | Canon imageRUNNER 3035 Black and White...
Canon iR6800C printer error code E000002-0001 pls fix this error code on photo coppier machin
Hi. You have to clear that error from service mode
Try to clear that error from service mode
press additional function
2 and 8 together
select copier
select function
select clear
select ERR
select ok. Unplug of the machine for 5 second and then turn it back on
try to make some copies, if problem persists fixing heater is damaged and need to be replaced
Mar 28, 2015 | Canon Office Equipment & Supplies
I'm trying to photocopy a book on a canon imagerunner 5075 without copying one page at a time and flipping the book around. Is there a way where the copier scans the right page and then scans the left page...
Hi Kim,
there are a couple of easy ways to tackle this problem. you have a book that when the spline is opened exposes 2 pages to the glass for the possibility of copying. What YOU need to determine is whether or not you want page 1 to ouput seperately from page 2, or , would you like page one to be on one side and page 2 to be on the second side. In other words auto duplex. That decision determines which feature you will use. I will walk you thru both. I realize you want the copier to scan the first page and then scan the second without you having to move the book around. I'm thinking you would be happy if the copier did that very thing and you wound up with a 2 sided copy with page 1 on the front and page 2 on the back. Here we go. Fom the main copy display locate the 2 sided button and select it. Select "book 2 sided" and follow the prompts. You could actually copy the entire book this way and when you are thru press "done" and here comes the avalanche!
If you want the images 1 sided on seperate sheets (not sure why) you can select "special features" from the display in the lower right corner and select "2 page seperation". same drill.
Apr 25, 2011 | Canon imageRUNNER 5000 Copier
Hp c6380 scanner issues
Contact HP for Care at 1-800-585-2494.
Jan 19, 2010 | HP Photosmart C6380 All-In-One InkJet...
Looking for a canon f50 multipass reference manual. Reason: trying to use flatbed scanner to scan - not the automatic document feeder. automatic document feeder works. The article I wish to scan does not...
To scan from the platen glass:
1. Click the "Setting" icon on the multipass toolbar
2. Select "Toolbar Settings" tab
3.Under "Image Source", click the "Scan From" drop-down menu and select "Platen"
Mar 02, 2009 | Canon MultiPASS F50 All-In-One InkJet...
I have a Canon printer (MP520) and I am trying to scan a document. It gets me to the point where it tells me to press a button (a black diamond) to begin and nothing happens, no movement. It photocopies...
check if your scanner add on software was installed into your PC like InfraView or other scanning software.
also check the connection from the unit into your pc.
Nov 05, 2008 | Computers & Internet
Canon NP 6030 photocopier is printing all black. Cannot rectify by altering shading setting. Appreciate any help to fix ASAP.
If it is solid black with no hint of an image in the backround, its an exposure lamp or exposure lamp fuse. Both are not user replaceable. To check, open the copyboard(lid over the glass) and push the print button. If you dont see the lamp come on under the glass it is most likely one of the 2 things mentionerd above.
Oct 30, 2008 | Canon Office Equipment & Supplies
Cannon NP 6035
2 things will cause this.
1 is a problem with the scanner: brokenn cable, dirty rails, dirty or faulty sensor, faulty scan motor or motor driver.
The second is much simpler. A stuck key on the keypad will lock the machine. Press every button on the panel to make sure each one makes the usual click sound as it is pressed. Sometimes just pressing the keys will cause it to become unstuck, other times the keyboard must be disassembled to remove the crumb, dirt, debris, etc, interfering with the key.
Sep 18, 2008 | Office Equipment & Supplies
89 people viewed this question
