Question about Canon imagePROGRAF W8200 InkJet Printer
Lines on prints
Having lines even after replacing the print head
  • 118 Answers
Hi
see in the bottom of the printer head there a projection to store the unwanted inks, it may be damaged while fixing the catrage
Posted on Mar 19, 2008
6ya staff
SOURCE:
I have a brother all in one MFC 685 CW &having problems printing
Not sure where you found the recommendation to use Windex on your print heads but chemicals should be avoided. It sounds like you have damaged so of the head elements and now they are leaking. There are specialized fluids for cleaning print heads or plain old water will dissolve ink as well. Too late for you however if the heads have been damaged they will need to be replaced.
Oct 06, 2016 | Brother MFC-685cw InkJet Printer
Printing white lines on label
Missing elements in print head, replace print head.
Nov 05, 2013 | Zebra ZP 450 Thermal Label Printer
Printer is printing with a lot of lines
If the lines you are getting are white then you have clogged print nozzles. Typically the nozzles clog when old ink plugs up some of the nozzles on the print head. These nozzles can't spray ink onto the page and you end up with white lines. You would need to replace the print head but I would recommend you clean off your cap and wiper assembly first. If you don't and there is a bunch of old ink built up, you run the risk of clogging up the new print head and having the same problem.
Nov 04, 2013 | HP Officejet Pro 8600 e-All-in-One Printer
Printer is having issues, prints documents like this (pic in details). Anyone know what may be wrong with it?
Print heads can get clogged causing lines and all other sorts of stuff. There is usually a setting to clean print heads in your printer tools.
There is also an alignment tool in your settings that is ideal for situations like this.
I've also found that sometimes if the quality is set too low like on draft for example. Lines may appear causing inconsistent prints.
Oct 06, 2017 | Dell 2155cdn All-In-One Laser Printer
When printing clip art, photos, etc. my graphics constantly have a series of evenly spaced lines crossing the art work. I can't find any printer head cleaning prompts. Even when I replace the ink...
Hmm, nozzles are blocked. Try Isopropyl Alcohol on a cotton tip or better still, a rag piece and run under the print head.
If this doesn't help, maybe this video will -
https://www.youtube.com/watch?v=CspEIN8EsZ4
Lastly, the printer should have come with a program that can clean the print heads.
Dec 24, 2017 | HEWLETT-PACKARD Hewlett Packard Officejet...
This evening I bought a new HP Photosmart C4780 printer. I am trying to print photos now and the photos are being printed with small vertical lines across the whole photo. How do I get rid of them?
> I bought a new printer
Take it back, and get one that does work correctly.
> VERTICAL lines ACROSS the whole photo
Hold the paper in "portrait" mode, not "landscape" mode.
Are the lines HORIZONTALLY-ACROSS the paper,
or VERTICALLY-DOWN the paper?
If those lines are WHITE and HORIZONTAL,
then some of the many ink-jets inside the print-head are *CLOGGED*.
Run a "print-head-cleaning-cycle" to try to unclog it.
Or, exercise the WARRANTY, and get it replaced.
Sep 24, 2010 | HP Office Equipment & Supplies
Mystery Print Problem with Canon iPF8000
If it's within 12 months of purchase, Canon will replace free, although you may have to hound them a bit. This problem has occured twice (2 new heads) on our IPF8100 each time about 9 months in.
Mar 09, 2010 | Canon imagePROGRAF iPF8000 Printer
Faded text every few lines- Canon printer
When you print photos you print in Max dpi, for this no faded lines anywhere. Probably you have a problem only in black color in print head.
Мay be it's partially clogged or partially defective.
Sep 28, 2009 | Canon i850 InkJet Photo Printer
Horizontal colored lines through grayscale printed photos
Hi George,
It sound's like an ink-feed issue:
1) Dirty heads, even after cleaning
2) No-ink or poor quality ink
3) Damaged head: some are part of the cartridge, some are not
4) Air bubbles in ink
The test page is typically not as hi-res nor as saturated as a
photo print. The hi-res photo puts the greatest demand on the print head.
The color lines you see are actually lines of missing color,
where the head has failed to deposit ink, so one or two primary
colors are missing from the complete picture.
For example missing yellow will make a blue line.
Missing magenta will make a green line
Missing cyan will make a red line.... etc..
Clean the heads again and again, print again and again,
hoping to flush the system.
BUT, keep in mind that cleaning wastes huge amounts of
ink and tiny little cartridges of ink cost more than many new printers.
Martin
Apr 24, 2008 | Canon PIXMA iP90 Mobile Printer
Printing lines
Hi. I've been looking for a solution to this very same problem, but I think that the only way to fix it is to replace the print head. I've spent a few hours now trying to find out if there is something else which could cause this problem, and the only one that applies to me (and to you, if you replaced all of your ink cartridges), is that the print head is no longer working. I found a print head for $50 at http://www.precisionroller.com/k_canon_i560_print_head/m114d5908c104/ , so I'll probably go that route.
Jun 11, 2007 | Canon BubbleJet i560 InkJet Printer
Canon imagePROGRAF W8200 InkJet Printer Logo
138 people viewed this question
Clive
Clive
old marine
old marine
Ekse
