Question about Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher
Dishwasher water in bottom of dishwasher
  • Anonymous Mar 12, 2008
    water doesnot drain completelky from dishwasher
  • Anonymous Mar 30, 2008
    the lights flash but the dish washer won't run and has water ing the bottom
  • 1,141 Answers
Check drain hose take it out and pour some water through it and check that it's not broken or blocked
Check the motor, look at it and see if there is somthing that blocks it same goes for the pump in the motor looks esppicaly at the belt.
Check the Drain valve,The drain valve is usually next to the motor also look for anything blockage
These are simple steps that if you follow them it will be easier for us (experts) to understand what is really the problem, please post your findinds for further help
Good day
Tom
Posted on Jan 03, 2008
After rinse fill the pump will not start
Hello, is there water in the bottom of your dishwasher? If there is water in bottom. Then try running the dishwasher throught another washing cycle. Now, if there is not water in the bottom of your dishwasher. Then the dishwasher has finished its washing cycle, rinsing the cleaned dishes. GB...stewbison
Sep 17, 2011 | Dishwashers
Dishwasher not working.... when i close the dishwasher and turn it on i can not hear any water running and there is a pool of water at the bottom that will not drain
Hello, How long has your dishwasher been do this? Have you washed dish's in it? Also, these German made dishwasher run on less than 2 1/2 gallons of water. These German manufactured dishwasher machines run really quite. Because of the German water conservancies laws. They limit the amount of water dishwasher and washing machine can use. Also, there is no storage hot water system in there homes, it on demand hot water. You can't hear the motor running and about the only thing one can hear is maybe the water washing the dishes.
Now, the water at the bottom of the dishwasher, if the drain isn't connected up under is the sink drain and trap area or the garbage disposable in the sink. but some place lower on the drain pipe. You will not have a spiffing effect on the the bottom of the dishwasher, it the same with washing machines. One the discharge pump starts sucking air, it will not drain the dishwasher. The siffen effect works if the water is below the outlet for the drain. Example: Home owner have the new washing running and continue fill with water. Why, because the drain pipe end is below the the bottom of the washing machine tub. It fill up with water and siffen action continues emptying the tube will it still filling. One heck of a water bill.
GB...stewbison
Aug 25, 2011 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
Our Bosch dishwasher has water filling back in bottom of dishwasher after cycle is complete. You can empty dishwasher and no water will be in the bottom, but several hours later the water has filled the...
Check the drain line underneath the sink.
It should be suspended just below the counter top.
If it is too low,water from the sink will back fill into the dishwasher.
If the drain is OK,then the dishwasher water valve is defective.
Mar 26, 2011 | Bosch SHU3306UC Built-in Dishwasher
Water leaking from the bottom of the dishwasher.
ck the float it may be comming under the door . if water is still in tank after cycle / clean the screen in the bottom it is a lift out basket . ck for resstriction in drain line . all of thes will cause over fill and flooding . your model may have a pressure sw . sometimes food gets in the air line / remove tube and blow out .. mm
Dec 02, 2009 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Water collecting at bottom of dishwasher. screens have been cleaned.
is there water sitting in the bottom of the dishwasher or on the floor? If its sitting in the bottom of the dishwasher, most likely the discharge pump isn't working properly and not emptying all the water out. The pump will usually run for an extended time to pump the water out until it finally times out and you're still left with water in there...
Sep 09, 2009 | Dishwashers
My whirlpool dishwasher is leaking water from the bottom of door
Water is being forced out under the bottom door seal. Is the lower spray arm melted on the bottom? Or is there something directing the water flow toward the bottom of the tub instead of up toward the dishes?
Sep 03, 2009 | Whirlpool 24 in. GU3200XTP Built-in...
Bosch dishwasher---water filling from the bottom when off?
i would replace the inlet valve. it sounds like it is not closing all the way
Dec 29, 2008 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Water in bottom of dishwasher
Hi You have a drain problem, Your house drain may be restricted the dish washer pumps out with more pressure then the water just falling down your sink.I would snake it or have a plumber clean out that drain...let me know if this helps krazytech
Aug 24, 2007 | Bosch 24 in. SGS43C12 Classixx...
Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher Logo
56 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
