Question about Fuji FinePix S3500 Digital Camera
Water inside S3500 Fujifilm
I was carrying my S3500 Fujifilm digi cam in my backpack and accidetnly the son's water bottle was open and so the camera became wet. It is 3 days us now and not the status is I can see my pictures but I can't take any photos and my zoom is not working now. Is there any thing that I can try. Since I love this cam I need this help.
Your help is much appriciated
Cheers
rjee
    Sergeant:
    Champion:
  • 317 Answers
Try taking it apart, and letting the pieces dry oput, or take it to a reputable camera shop, and see if the can replace one of the boards that might have short circuited, otherwise it looks like you need a new camera :( Sorry.
Posted on Jan 09, 2008
What kind of hand truck should i get if i need to carry gallons of water bottles daily?
For carrying a lot of gallons of water bottles the best hand truck is the convertable one, that allowes you to tilt the base so that it will create a slope with a stopping bar at the end, where you can pile up the bottles without them rolling down nor being completely vertical.
Another option, if you need to carry 5 or less bottles, is the vertical hand truck that allowes you to set a couple of bottles on the bottom, and than has little concave shelves where you can set a bottle after the other, resting on the round shelf so that they dont roll down.
Jan 05, 2014 | Tools & Hardware - Others
My Panasonic Lumix TZ5 died after apparent exposure to drinking water several days ago. It was turned off with battery installed and in a leather carrying case which was soaked. I removed the battery...
The only way to fix this problem is to get it repaired.The water has entered into your camera and it is possible that motherboard inside has been burnt or there is still some water inside. you can try one home remedy.Take you camera apart and then blow a compressed air or you can use a hair dryer to dry water inside.
Jul 22, 2008 | Cameras
What is bottle water
Bottled water. Generally bottled water is just a glorified tap water. However there are many things that go on to put water into a bottle. It is chemically treated things such as ozone is added.among other things as it can't just be plain water, some of these bottles have to remain on shelves for a very long time. But rest assured no one would ever do anything that could harm us, now would they. Some bottled water is actually really what we would hope it to be like some of the spring waters that are out there are actually from mineral springs. However in my personal opinion I think it's all the biggest scam in the world, we bay more for a bottle of water than we do for a liter of fuel to run our cars on & it's just water it falls from the sky for free. Think about it people.??????
Sep 18, 2013 | Dasani Drops TM, Strawberry Kiwi, 1.9 Oz.,...
How do i clean the boiler
Brown water and white scale are often the result of the water you use in the iron...
If you have scale, white vinegar will clean that...
For brown water, empty the iron, rinse out the insides with bottled water,
and then use the bottled water instead...
Also check out this tip...
Cleaning a Steam Iron White Scale and Brown Water
heatman101
Apr 21, 2011 | Irons
Rust colored steam that stains clothing ironed
Hi, Brown water and whitescale are often the result of the water you use in the iron... If you have scale, white vinegar will clean that... For brown water, empty the iron, rinse out the insides with bottled water, and then use the bottled water instead...
Cleaninga Steam Iron White Scale and Brown Water
heatman101
Mar 22, 2011 | Rowenta DZ1700 Iron
Brown water spitting out of bosch steam iron
heatman101
Feb 03, 2011 | Bosch TDA8340 Iron
I have 1998 740i BMW that is overheating. 1) What are the warning signs of a bad water pump? 2) What are the warning signs of a blown head gasket? 3) What are the warning signs of bad timing?
Timing - engine is not sounding right or back firing.
Head gasket - water and oil mixing, see inside water bottle. or open bottle. rev engine when cold, if starts spitting water out while cold like a fountain.
Water pump - Water leaking from side of engine. or when car started and water bottle is open and no circulation is visible could be signs of water pump
Remember - Block radiator lines can also cause over heating problems and lack of water circulation.
Jul 18, 2010 | 1998 BMW 7 Series
My son's car overheated. Went to get some anti
The overheating is caused by the sludge. It is very easy to correct this problem. Remove the radiator cap and open the drain valve at the bottom of radiator. If possible, remove the reservoir and flush out with water. Make sure to get all sludge out of reservoir, then reinstall. Once the radiator stops draining, insert water hose (without nozzle) and turn water on. Keep the drain valve open. Run water through radiator until it runs clear. Once it runs clear, start the engine and let it run while keeping the water running through radiator. Allow engine to run until the thermostat opens up. Continue running water through radiator with engine running until the water from drain runs clear. Once you have done that, turn off the engine. Close the drain valve and refill radiator with proper mixture of coolant and water. Once radiator is filled, start engine and let circulate through engine. Coolant level will drop as the coolant starts circulating. Shut off engine and top off radiator. Fill the reservoir with the required amount of coolant. Testing the coolant at least once a year will help prevent this from happening again. Coolant should be replace a minimum of five years, less if coolant bottle specifies.
Jun 20, 2010 | 1994 Pontiac Grand Prix
Software
Hi Diane
Yes there is alternate solutions exist. for FinePix Viewer you can get the software from FujiFilm's support website as I am adding the link below as;
http://www.fujifilm.com/products/digital/download/index.html
you can download or update related software.
Also you can see the list that your product has been marked as vista compatible
http://www.fujifilm.com/products/digital_cameras/support/compati_vista.html
Please post your questions if you need further assistance
Good Luck
Jan 20, 2008 | Fuji FinePix S3500 Digital Camera
Fuji FinePix S3500 Digital Camera Logo
61 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Fuji Camera Expert? Answer questions, earn points and help others
