Home | Sony | KP-46WT510 46 in. Rear Projection HDTV Tel... | Picture is blurry and...
Sony KP-46WT510 46 in. Rear Projection HDTV Television
Problem for Sony KP-46WT510 46 in. Rear Projection HDTV Television
Picture is blurry and looks warped. Waves of pink
By claudemcdona on Nov 02, 2009
Picture is blurry and looks warped. Waves of pink and green in upper left corner.
Best Solution
posted on Nov 02, 2009
Very Helpful)
SD Tech
Rank: Guru  Sony Televisions & Videos  Expert
Rating: 97%, 850 votes
IF you go into the customer menu and select CONVERGENCE and red or blue will not move in some direction--or if green is skewed--you have a convergence problem.
I can give you specific instructions about repairing this if you know how to solder and have some skills.
If you have any questions or need advice let me know-I am here to help people.
if this information helped you rate this solution--I do this here for free.
SD TECH
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
Helpful)
asnowman
Rating: 96%, 540 votes
What you might be experiencing based on your symptom sounds like a damaged convergence IC.
With any Projection Television that has a damaged convergence IC, you do not want to continue the use of the set. If the IC’s continue to fail they will cause a short in the power supply and cause your television to not power up, and possibly damage the CRT’s in the set.
With that aside I have some support suggestions that I have put together that may help you make an informed decision.
You should be able to get a local service center to repair this at your house for between $350.00 - $450.00, If you want to repair this set yourself, I have some instructions below that will be a help to you.
While it is not a very hard repair, this repair can be a bit tricky. If you have a 45W soldering iron, solder, solder wick, and heat sink compound you can repair it yourself.
When you remove the old IC's, please be sure to remove all of the old heat sink compound, as it can act as an insulation for the new IC's and cause them to overheat. I usually clean the heat sinks with alcohol and a small rag.
There are two and large IC’s that control the convergence in a big screen set. Some of the newer sets only have one. If you only have one, it is right in the middle of the set on the center circuit board. They are secured to a very large aluminum heat sink. They will have a part number stamped on them that will start with an STKXXX-XXX, like STK392-110.
Along with the convergence IC’s there will also be some associated components that will need to be replaced as well. There are some resistors that are part of the convergence circuit that will be open and need to be replaced. Most likely these will appear charred in the center. If you have an Ohm Meter or a DVM, check all the resistors that are close to the IC’s and you should be looking for either ones that have opened or have changed values.
If one of the convergence IC’s are found to be bad, I would replace them both, if one has gone bad the other may go soon. I usually order my parts from Andrews Electronics in California, they will have the OEM components that you will need.
Their site is
http://www.andrewselectronics.com/welcome.aspx
And their phone number is a 24-Hour Order Desk: (800) 274-4666
I recommend the phone order so you can talk to the person about the different types of IC’s that are available.
I would also advise that the convergence IC’s be OEM or better, just because they are cheap does not mean that they are a good deal. I have seen the cheap IC’s fail after a short time, even though they look exactly like the OEM IC’s. I think that the bottom line is that you will get what you pay for when it comes to the parts.
You can also try
http://www.tvrepairkits.com/ , I have not tried them yet, but they do carry OEM or better parts.
I hope this information allows you to resolve this issue.
If you need further assistance please comment to this post and I will try to help you further.
Thanks for using FixYa
asnowman
I have attached some photos of really bad convergence problems; your picture may not be exactly as bad as these.
Was this helpful?
Yes
No
3 people thought this was helpful
Solution #3
Not Rated)
Chu3505
Rating: 85%, 388 votes
Convergence is dead,know how to solder?Buy a convergence kit,use what in that kit.Tries Tv repair World.com,Tv repair kits.
Comments:
Nov 02, 2009
- Convergence is dead,need a convergence kit,buy it from Tv repair World.com,Tv repair kits.Know how to solders?
Was this helpful?
Yes
No
Popular Solutions for Sony KP-46WT510 46 in. Rear
Questions and Unsolved Problems for Sony KP-46WT510 46 in. Rear
Do you recommend Sony KP-46WT510 46 in. Rear Projection HDTV Television?
Answer
Answer
I have a Philips Magnavox Projection TV. I had dish satelight install on my TV. It worked well for... (More)
Answer
the tv picture looks like should be wachting it whith 3d glasse
Answer
replaced convergence clips and blue wave will not line up can move but way off
Answer
How do I get the front panel off my Sony 46in projection tv to adjust the red line conversion.
Answer
Our picture is visible but is in blue tint. How much is that to fix, around? Is there anything... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Sony KP-46WT510 46 in. Rear...:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 689
Experience: 30 Years of professional repair and design.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
