Question about Kenmore 24 in. 15079 Built-in Dishwasher
Dishwasher doesn't drain fully
Hello, I have a Kenmore Elite built in dishwasher; Model 665.15979992 , S/N FK10107927 , Stock # 15979 which won't drain completely. I checked for obstructions on the inside of the unit as well as the drain hose and both are clear.
Any ideas or tips would be helpful as well as an indication of the age of the unit so I may determine if its worth fixing or not.
Thanks for you help.
  • 2 more comments
  • Anonymous Jan 09, 2008
    kenmore dishwasher won't drain fully
  • Anonymous Jan 13, 2008
    I have the same problem with my Kenmore Ultra Wash dishwasher. Any suggestions would be appreciated.
  • Lex van Loon Jun 03, 2008
    Hello Reg501,
    You hit the nail on the head. That was exactly the problem. I'm afraid I had to have a repair person fix it for me but hope this tip will help others with the same problem.
    The fix is surprisingly easy to execute (once you know how (of course)).
    Thanks for the help!
  • bdavis386 Oct 18, 2008
    I also have a drain problem The motor will run through all cycles eccept to drain, I pulled down the long drain hose and all the water drained out just won't pump out. it will wash and everything else works great.
  • 413 Answers
Some model 665 DW have a check valve that is attached between the sump and drain hose that may have a blockage..... Remove the drain hose from the long plastic valve then carefully unscrew the check valve from the sump. Inspect for debris.
Posted on Jun 02, 2008
I have a Kenmore Elite, Model # 665 stock # 15979. The Lock-On light flashes but the unable to Un-Lock it. When I press Canel both lights flash, unable to canel it unless I open the door
here are a couple methods to try....
hold whichever one of these buttons you have on your model for 3+ seconds....
Air dry
there are a lot of other things that could be the problem but these are common
Jul 27, 2015 | Kenmore Dishwashers
Why kenmore elite dishwasher will not drain?
If it is connected to a disposal remove the drain hose and check for a restricted area in the hose or disposal this is common also check the drain hose for kinks be sure to elevate the hose before the drain area. If the drain hose is clear and the drain is clear then you could have a bad drain pump in the dishwasher.Most problems are a restricted drain or hose
Jul 22, 2014 | Kenmore 24" Built-In Dishwasher with...
Jenn air dishwasher won't fully drain
Your garbage disposal is clogged . Or your hose from your garbage disposal is flowing in the down position
Oct 22, 2012 | Kenmore Elite 45986 Front Load Washer
Kenmore elite dishwasher model 665,15979992 remains locked - won't unlock
Depress and hold the heated dry button until the light goes out. This may take more than the suggested 4 seconds (Sears suggestion).
Sep 15, 2009 | Kenmore Dishwashers
Kenmore Elite model 665.17052400 dishwasher will not drain
Check disposal to see if d/w knock out was removed form disposal. If so check drain hose for kinks or restrictions.
Ie unistally hose from disp and see if d/w will drain into bucket. IF not uninstall d/w and check for kinks.
Jul 18, 2009 | Kenmore 15899 Built-in Dishwasher
Hello. Are you using liquid or powdered soap? In some models liquid soap will foam up and the drain motor can't pump out bubbles. Foaming can also happen if you pre-clean your dishes with liquid soap used for washing by hand. If it is foaming, you can poor non-dairy creamer or cooking oil into the bottom of the unit while it is in the wash cycle.
If foaming isn't a problem then the water level switch may be bad, the pump may be not pumping out as quickly as it should or you may need to take the hose off completely to make double sure that there isn't anything in it.
Did you check the air-gap next to your kitchen sink faucet. If you don't have an air-gap it may be hooked up to the garbage disposal and if you don't have a high loop in your drain hose the water can run back into the dishwasher especially if the disposal backs up.
Dec 03, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Kenmore Quietguard Plus/Ultrawash - Kenmore
drain hose may be partially clogged or kinked up. ensure that the hose is not bent up thus restricting the flow of water out.
Nov 26, 2007 | Kenmore 16602 / 16604 / 16609 Built-in...
Kenmore 24 in. 15079 Built-in Dishwasher Logo
1,650 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
