Take a pencil eraser and gently clean the battery contacts, as well as the new battery. Probably oil (from your skin) came off the batteries (did they leak?), and contaminated the contacts. using the pencil eraser will allow you to GENTLY poke down the cavity where batteries go and try to clean contacts.
If you are using nicd batteries, most devices will show a lower charge vs. a set of alkaline batteries. Most devices dont care. Those that do, just dont use nicd or nimh batteries in them.
I can't get the camera to turn on it has the lens out and won't turn on. I have replaced the...
(More)
I can't get the camera to turn on it has the lens out and won't turn on. I have replaced the batteries a couple times and sill it won't turn on
Hi, Inside photos are fine but outside photos are coming out white. New problem just discovered...
(More)
Hi, Inside photos are fine but outside photos are coming out white. New problem just discovered yesterday and i am going on a trip tomorrow. In manual looks like it could be metering setting but i cant find that adjustment on my menu
