Home | Jenn-Air | JCD2389G Side by Side Refrigerator | Freezer ok refrig war...
Jenn-Air JCD2389G Side by Side Refrigerator
Problem for Jenn-Air JCD2389G Side by Side Refrigerator
Freezer ok refrig warm / cleaned compressor area.
By r_conn1 on Nov 02, 2009
freezer ok refrig warm / cleaned compressor area. what's next?
Best Solution
posted on Nov 02, 2009
Very Helpful)
milten1
Rank: Guru  Jenn-Air Refrigerators  Expert
Rating: 90%, 472 votes
you will want to llok in the back of the freezer section and make sure the coils are not frozen or make sure you do not have frost on the back wall.....
while your back there hold the door switch closed listen for the fan to make sure you have proper air flow thru the unit
next close the freezer door and see if you can feel the air in the aupper left corner
this model tend s to loose its defrost
Comments:
Nov 02, 2009
- the best thing to do here is move your food to a working unit,
you will want to know if its your defrost control
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=47455&diagram_id=641761
that link will take you to a parts store and a visual breakdown your looking for the control section
part 13 adaptive defrost,, this os more than likely yhe culprit,, they short when get to moist
this unit should go into defrost, by pushhing the door switch 5 times very quickly
if it does not work im pretty sure its the board
hope thius helps
have a grteat day
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
" Very helpful! I have frost build up on the back wall of the freezer and no air flow into the refrigerator. " - r_conn1
Popular Solutions for Jenn-Air JCD2389G Side by Side
Questions and Unsolved Problems for Jenn-Air JCD2389G Side by Side
Do you recommend Jenn-Air JCD2389G Side by Side Refrigerator?
Answer
Answer
our jenn air refrigetator coil is freezing and refrigerator side does not stay cold. If we unplug... (More)
Answer
rust stain spots all over the fridge. front and side. could it be because the stove is next to it?... (More)
Answer
How do I "unlock" the water and ice if my kid accidentally locked it?
Answer
intermitant vibranting noise & running frequent Westinghouse side by side 10 years old
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Jenn-Air JCD2389G Side by Side...:
Top Refrigerator Experts
Rank: Guru Guru
Solutions: 881
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Refrigerator Experts
Top Refrigerator Repair
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(619) 564-4488
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
