Taking too long can be very difficult to troubleshoot because term is quite relative. A load of bed linens will dry much quicker than a load of jeans.
Check your dryer vent (usually outside) to see if a bird or critter has made a home. Then check your vent hose. Same thing, look for buildup of lint here. Check your filter as well. See if there has been any lint that has built up and fallen off the filter (look down in tube, holder, etc).
Since dryers use room air to circulate with, and then expel it outdoors, also make sure that there is adequate air flow to the dryer. Open a window in same room, if you can. If it improves, then your house is sealed up tight (and that's the problem).
Was this helpful?
Yes
No
Popular Solutions for Maytag Bravos 7.0 Cu. Ft. Gas
Hi - problem with Zanussi ZWD1472W washer / Dryer. Everything seems to work OK (washes / spins /...
(More)
Hi - problem with Zanussi ZWD1472W washer / Dryer. Everything seems to work OK (washes / spins / programs) with no error messages BUT nothing heats up. No hot water. No dry clothes. The front door does not even get warm. Any suggestions? Thank you
were can i get a belt for a conia dryer model ccd 4501 this was brought from kmart and no longer...
(More)
were can i get a belt for a conia dryer model ccd 4501 this was brought from kmart and no longer stocked
dryer worked for the first week i had it, now it does not heat up and i am getting gas to the dryer...
(More)
dryer worked for the first week i had it, now it does not heat up and i am getting gas to the dryer but no smell of gas when unit is running
