Copiers
Problem for Copiers
Generic problem for all Copiers
Bizhub Di5510
By Kris Ratliff on Jan 03, 2008
What does the error SC49-01 on the Bizhub Di5510 indicate?
Same Problem
Nov 18, 2008
-   We have the same problem, just got this copier and now we are trying to set it up, keep getting that error, where can I find the firmware update and how do we turn off using the control panel?
Thanks in advance...-   eblogan
Best Solution
posted on Jan 03, 2008
Very Helpful)
sir fixalot
Rank: Guru
Rating: 92%, 233 votes
SC49-01, SC49-02, or SC49-03 codes.
[Solution]
PROBABLE CAUSES:
1. Outdated firmware.
A flash ROM upgrade is available to correct this problem.
Notes:
a. See bulletin 3481A for details on this issue.
b. Make sure that the current version of system software (with applicable patches) is installed on the controller.
2. Improper shut down procedure of the controller.
Here is the correct shutdown procedure:
a. Shutdown the controller via the Di5510 control panel.
b. Turn off the sub switch (front switch) of the printer.
c. Turn off the main switch (rear switch) of the printer.
This procedure assures that the controller and printer are properly synchronized when power is applied. If the sub switch (front switch) is the only switch turned off, the Service Code will be generated the next time the printer is restarted.
Was this helpful?
Yes
No
Popular Solutions for Copiers
Questions and Unsolved Problems for Copiers
Answer
What do customers think of the the Toshiba e-studio 5520c, as we are considering buying one?
Answer
I was trying to run a pdf document of 600 pages. It printed first two pages and then stopped( on the... (More)
Answer
error code p24 troubleshooting
Answer
I have a new PC but it not recongnize teh Bizhub 10 printer I have
Answer
trouble shooting code book or manual for a panasonic Fp 7735 copy machine
Describe your Copiers problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Copier Experts
Top Copier & Fax Repairmen
in Newport, KY
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
