I installed a new flowtec shallow well jet pump and a 40 gallon pre-charge tank. I followed all the directions to the letter while installing the plumbing and pressure settings. The pressure at the pump is set to 60psi. However I don't have very good pressure and if I use something I have none at another water location. For example use the washer I would not be able to use the sink or even the toilet. I would have to wait until the washer is done. This is **** and I can't figure it out. SOMEONE PLEASE HELP!!!
It sounds like our pump is not priming, or is losing its prime (bad foot valve maybe?). There may also be a blockage on tank outline from some sort of debris that washed out of tank during install.
dyson cr01 showing fault 70 600 2701 when i clear it by following the hold temp while turning on and...
(More)
dyson cr01 showing fault 70 600 2701 when i clear it by following the hold temp while turning on and pressing soil within 3 seconds i get the next fault showing f11f10f11v130
my dyson cro1 is saying not filling but there is water in the drum then the washer stops it seems to...
(More)
my dyson cro1 is saying not filling but there is water in the drum then the washer stops it seems to fill on the left side of the powder draw please help me
