Problems with my 61 inch phillips t.v.,need help a.s.a.p.
Ok, well i bought this tv about 3yrs ago,4 tops. and for the past month or so the tv has been acting strange, the picture was unclear when turned it on, but after about 10-15minutes it would come in but then at times the picture would go small then big,small then big, then sometimes it would go out. and now when i turned on my tv today theres no sound and no picture. whats wrong?...ive been trying to find out but everyone wants a fortune just to give me an estimate. what can i do and how much is it gonna cost me? cus i cant buy another one right now,plus it being 61 inches it cost a pretty penny, so please,help!
it is a phillips magnavox and model number 9P60349103
  • awashd32 Oct 06, 2008
    I have the same TV, I started experiencing this after moving it from upstairs to the basement. I'm trying to determine is it cheaper to just buy another TV.
  • Anonymous Nov 21, 2008
    SAME ISSUE
  • 8,617 Answers
Can you explain more about what you mean by big then small? When the picture got small do you mean it shrunk down in size leaving a black screen around the perimeter? Or did it bow in from top bottom? If you van acurately describe what it was doing I may be able to point you into the right direction on diagnosing the problem.
Posted on Jan 03, 2008
Tv is on with no picture or sound, only 4 months old!!
Hello
The power supply regulator board to your set has the fault. If you try to open the set, or try to repair it by yourself, the warranty will void. The set must have warranty as it is new. Why do you spend for it? Just contact the nearest authorised service center for Sceptre. the components in this set will be very hard to get from open electronic spare part market, and will costly too.
Mar 11, 2012 | Sceptre 32 X320BVHD 32 LCD TV
My 50inch cuts on and off so i replaced my bulb or lamp it help for about 4 months now its doing it again,but this time i have small lights all over my screen i purchased the tv at walmart 3yrs ago they...
If the lcd lamp has been changed then the problem is with the inverter board, this board acts a bit like a switch to turn the lamps on, it is either a seperate board inside the set, although some lcd tvs have the inverter built into the power supply board, you will probably have to visit the manufacturers site for this information and they should be able to supply a board for you. hope this helps.
Aug 21, 2010 | RCA Televison & Video
Samsung DLP TV; Green Lines
If you get green vertical bars or green dots in the picture but not in the menu screen (Digital board symptom)
Feb 28, 2010 | Samsung DLP HL-P5663W 56" TV
My 52inch xbr4 tv is 2 years old. Intermitently over past 2 months, when I first turned it on, I get thin vertical lines and double imaging especially over left half of screen. After a few minutes it would...
I have the same issue. Bought the TV 1/08 and it started showing those exact symptoms about 3-4 months ago. It generally progresses and gets worse. You can try to fix it as it's some kind of TAB connector issue, or keep calling Sony so that the 52" owners of the XBR4 and 5 series get the extended warranty just like the 46" owners received for the same series. If enough of us keep calling, they'll have to act.
Jan 18, 2010 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
Bought a 50inch Wega 3yrs ago. Been great until
maybe your tv is getting to old or somebody droped it
Nov 01, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Philips tv model id: 19pfl5422d/27 terrible loud sound
The issue is 4 1000uF X 10V on the main board under the shield close to the connector that from the power board. you will see them because they will be FAT( exploded)
Feb 28, 2009 | Televison & Video
Blurry Picture
I too had the same problem where my HT30744 TV would lose its color or picture would get blurry. My mom's HT32744 would have the same problem too. They both are refurbished models bought at Value City Dept store. If I gave the cabinet a good hit it would mostly fix the color, but it could also make the picture go fuzzy too, a clear sign of just a loose connection somewhere.
So after my wife telling me she was sick of this almost 2 year problem and she was going to buy a new TV on the weekend, I figured I had nothing to lose. So I took the rear cabinet off, unseated the card mounted on the picture tube, applied a little dielectric grease on the connector on the card and reseated the card, removed, re-greased and reattached the card. I have had no problem with either my or mom's which I did the same to since! This is an easy fix that anyone can do. The hardest part is moving the TV and reassembling the rear cabinet. Do not pull the cabinet back out more than you have to, to ease the reassembly of it.
May 06, 2008 | Sanyo HT32744 32" TV
Lines on tv
Set starts, horizontal and vertical deflection work, HT ok, crt heaters ok, but no sound or picture
I turned the G2 voltage up and noticed a white screen with flyback lines, frame ok. I detected two badly soldered double diode rectifiers in the secondary part of the power supply ! I checked all other joints, and everything was ok !! success
White horizontal line (no vertical deflection)
Check / replace R548, R549
Sound but no picture except for a couple of horizontal colour lines
Replaced the frame chip TDA8356, set now ok
Nov 23, 2007 | Mitsubishi WS-65511 65" Rear Projection...
Vizio GV42L LCD TV screen black when turn TV on first time
If you are using a set top box this might be caused by turnig the box on at the same tie as you turn the tv on or slightly after you turn the tv on.  If you are using compnent or HDMI inputs the set needs to see the signal as it is turned on to know what formt the signal is in.
Oct 15, 2007 | Vizio P2 42 in. HD-Ready Plasma Television
Televison & Video Logo
436 people viewed this question
Top Televison & Video Experts
