Question about Hobart 24 in. LXIC-5 Built-in Dishwasher
LX dishwasher I need the codes for a Hobart LX dishwasher
  • bsisson Jan 14, 2008
    The fault codes the the unit displays when it is having a problem
  • Anonymous Mar 14, 2009
    e7--probe malfunction ~~ How can I fix this?
  • 640 Answers
What codes do you need?
Posted on Jan 12, 2008
  • anthony james
    anthony james Jan 15, 2008
    heres the codes__p1--sump error,p2---rinse probe error,p3---booster probe error.eo--water below bottom sensor,e2--water not at sump sensor during fill,e3--water not at middle probe during fill,e4--water not at high probe during fill,e5--top probe at rinse,e6--temp probes,e7--probe malfunction,im a service tech for hobart and service these machines all the time.any ? let me know.
  • Minh Than
    Minh Than Nov 18, 2016
    how can i fix error code E7???
E7--probe malfunction ~~ How can I fix this?
Posted on Oct 08, 2008
How do I fix an e-5 error
Posted on Aug 21, 2008
3 Suggested Answers
  • 93 Answers
SOURCE: hobart dishwasher lx 30 h
Did the clean light indicator blinking over n over? check the element wire harness connector. If disconnected fix it and run your dishwasher again.
Also you may check the continuity of your heating element.
Posted on Jul 23, 2008
bigg t
  • 640 Answers
SOURCE: what is p3 code on hobart am15 dishwasher
It means that the final rinse thermistor is bad.Your not getting 180 degrees---right?Its located on the booster and costs about $65.I work for hobart.Any ?
Posted on Jan 25, 2009
Why does our Hobart lx 30C Pump out at start of wash cycle?
Could Could the anti syphon blocked? I'm guessing the drain pump doesnt operate while this happens
Jan 16, 2018 | Hobart Dishwashers
Need bushing for sprayarm and repair manual
The wash arm bushing for this model is not available separately. You can use the bushing from the LX series and cut it shorter to length. Hobart will not issue service manuals to non Hobart personel because of liability issues. If you injured yourself from misinterpreting the manual, they would apparently be resonsnsible.
Dec 08, 2013 | Hobart SR24-H Built-in Dishwasher
Hobart LX 30 undercounter dishwasher, commercial Does this model require booster?
Most of the Hobart LX series of dishwashers have their own built-in booster heaters. To check for one, remove the lower front panel (2 screws). The booster heater, if present, will be a stainless steel tank on the left side. If it doesn't have a built in booster heater then it was meant to be used with chemical sanitizer instead.
Jun 29, 2011 | Hobart 24 in. LXIH-3 Built-in Dishwasher
E3 Error code on hobart lx30 dishwasher.
my dishwasher Hobart LX 30 will not shut off and displays 30
Jan 21, 2011 | Hobart 24 in. LXIH-3 Built-in Dishwasher
LX-18 error code E4 what is the problem? Replaced motor runs great.
the water does not seem to be pumping to wash the dishes....could something be plugged? I can hear the pump and it pumps the water out at the end...
Mar 06, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Hobart LX 30H shuts off and turns back on by itself
Hello Jon,
I work in the product service department for Hobart Corp. and work mainly with the Hobart dishwashers. The most common problem with what you have going on is a faulty keypad on the front of the unit. This is the component with the actual on/off/wash buttons on it. If the problem is very frequent, then you could contact your local Hobart service office and they could come out and troubleshoot the problem to be certain that this is the faulty part before just buying a part and hoping that it works. If you would like to discuss this a bit further or need assistance as to a contact for your local Hobart office, you can contact us at 937-332-2525, and press option #2.
Have a great day!
Jim
Nov 28, 2008 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Hobart lx 18 warewasher what hatco booster heater product compatable with it
The answer to this question will be based on the incoming water temperature that is supplied to the booster heater. The standard sizing for a booster heater is based off of a 40 degree F rise (140 degree F incoming water temperature) or a 70 degree F rise (110 degree F incoming water temperature). For a 40 degree F rise, a Hatco model C-5, S-5, or PMG-60 will supply the needed amount of rinse water for the LX-18 Hobart dishwasher. A 70 degree F rise would require a Hatco model C-9, S-9, or PMG-60 to supply the same Hobart model number.
Oct 11, 2008 | Dishwashers
Hobart dishwasher lx 30 h
Jul 23, 2008 | Hobart 24 in. LXIC-5 Built-in Dishwasher
Hobart 24 in. LXIC-5 Built-in Dishwasher Logo
928 people viewed this question
Top Hobart Dishwashers Experts
Jason
Garth Jackson
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
