assuming that the circuit breaker or fuse is not blown, this is most likely caused by the door switch. if the door is not closed, the dryer will not turn on, period. you will have to try to jump over the 'possibly bad' switch. first, shut off the breaker. second, wrap a putty knife with masking tape to prevent scratching up the dryer. then, use it to pop open the plastic catch on each front corner. take your time and look inside the small gap with a flashlight to help figure it out. after you have the top of the dryer safely tilted back, look for 2 wires running to the door. they will plug into a switch that is flipped when you close the door completely. you know what i mean, it probably used to click when you shut the door. unplug these wires from either side of the switch. use a piece of wire to connect them or just tape the metal ends together. this will bypass the door switch. make sure all metal parts of the wires are covered to prevent a short on the metal walls. be sure the now loose wires will not get caught on anything, like a rotating drum. close the lid most of the way. turn on the breaker and try to operate the dryer. if it now works, replace the door switch. be careful, opening the door will not shut off the dryer now. good luck
Was this helpful?
Yes
No
Popular Solutions for Kenmore 62802 Electric Dryer
I have a Kenmore Electric Dryer Series 80 Model 110.86980800 MX4737306. The heating element works -...
(More)
I have a Kenmore Electric Dryer Series 80 Model 110.86980800 MX4737306. The heating element works - it's bright red when I open the door. My problem is that there is a hot, burning smell coming from something. All lint has been cleaned out of everywhere. Any assistance will be helpful. Thanks!
I have same situation. Runs fine but does not heat. Yesterday, heated for first 10 minutes, then...
(More)
I have same situation. Runs fine but does not heat. Yesterday, heated for first 10 minutes, then door opened on its own (another problem). Started up again, but no heat after door opened. Next day, no heat. model number is 11072822101
I have the same problem - wont stop, just cycles threw all the setting until we open the door to...
(More)
I have the same problem - wont stop, just cycles threw all the setting until we open the door to stop it. It Does dry and tumble, just keeps going.
Select a cycle and it lights up...then nothing but a clicking noise when you hit...
(More)
Select a cycle and it lights up...then nothing but a clicking noise when you hit start.............almost 6 yrs old
dryer times out after just a few minutes on both the moisture sensor and timed dry. The timer and...
(More)
dryer times out after just a few minutes on both the moisture sensor and timed dry. The timer and temperature sensors have been replaced.
