Question about Ricoh Aficio CL2000N Laser Printer
Ricoh 3500L fax machine
We want to receive faxes, we noticed the receive file led is lit after someone sent us a fax, how do we receive the files
    Scholar:
  • 152 Answers
I think you are in manual mode.. try searching for an auto mode, or a big button to receive faxes.. ... in manual mode, the guy should usually ask (in a call) you to give you feed so you give him line by pressing some big button.. and you also need to always have paper.. otherwise it wont be done
Posted on Jan 03, 2008
Fax forword ricoh mp171
Print documents received and forward to a specified end receiver. This is useful if, for example, you are visiting another office and would like a copy of your documents to be sent to that office.
You can also specify a "folder" as the forwarding destination.
  • To use this function, set [Forwarding] under [Administrator Tools] to [On].
  • The Forwarding function does not forward documents received with Memory Lock.
  • You can select end receivers only from among destinations programmed in the Address Book. You cannot specify programmed transfer stations as end receivers.
A fax number, e-mail address, IP-Fax destination, and folder can be set as the forwarding destination.
When you wish to change the end receivers depending on the senders, specify the end receivers by the senders, at "Program Special Sender". Documents not received from specified senders are sent to the destination specified in this function. For details about programming special sender, see "Program Special Sender".
You can set whether or not to print the forwarded documents on this machine in "Parameter Setting" (switch 11, bit 6). See "Parameter Settings".
Deleting a destination specified as a forward destination from the destination list causes the settings of the forward destination to be deleted, so they must be registered again. When a destination is changed, a document is transmitted to the new destination. If there is no destination of the specified type, you can set which destination to be used as an alternative destination in "Parameter Setting" (switch 32, bit 0). See "Parameter Settings".
You can program one of the User Function keys with operations for this function. See "General Settings/Adjust".
If you have specified a folder for forwarding, you can specify the file format used for forwarding in "Parameter Setting" (switch 21, bit 3). See "Parameter Settings".
User Parameters (switch 37, bit 4) on the Fax Features menu allows you to include the sender's name in the names of files sent to folders. However, garbling of the file name and data loss can result if the receiver's operating system cannot accept certain characters in file names. To prevent this, use User Parameters (switch 37, bit 5) to limit the file names to plain characters only. If you limit file names to plain characters only but errors still occur, disable display of the sender's name in the file name of documents forwarded to folders. For details, see "Parameter Settings".
Using the parameter setting (switches 38 and 39), you can specify the maximum number of resends that the machine attempts if it fails to forward a fax (including faxes from special senders) to a folder destination, and the interval between the resend attempts.
or download the operations manual to guide you here ..http://support.ricoh.com/bb_v1oi/html/oi/re/model/mp171/mp171en.htm
Mar 24, 2013 | Ricoh Aficio Office Equipment & Supplies
Faxs sent are being received with streaks I have cleaned the LED print out head but nothing changes
The LED print head has got nothing to do with fax's being sent. Clean the glass strip underneath the ADF.
Oct 17, 2010 | Muratec F320 Plain Paper LED Fax
Ricoh fax 120 please let me know how to put ricoh on automatic fax receiving while not in the office also when someone rings i can hear the fax sound from my ricoh
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} - Follow the next instructions to change the reception mode :
1. Press the [F2] key. “ this key is located on the left side of the Control Panel next to the key [12] from the left side and next to the [Memory Trans.] key from the rigt side ”
2. Press the left arrow key to select the reception mode “ this key is located under the Display of the Control Panel”
3. Press the [OK] key when on the display is displayed the mode you want.
note:as you sad you want the machine to reaceive faxes when you are out of the office, so the reception mode [Auto Select] is the most compaible mode for you.
The machine can treat incoming fax
messages and telephone calls in three
ways.
1.Manual Receive
- Use this mode if your line is shared
by a fax machine and a telephone
but you wish to answer all calls
yourself and decide whether they
are fax documents or telephone
calls. You must manually press the
[Start] key to receive a fax.
The machine will ring continuously
until you answer the call, so you
have to be near the machine at all
times. The Manual Receive indicator
is lit when the machine is in this
mode.
2. Auto Receive
- Use this mode if you have a dedicated
fax line. The machine assumes
all calls are fax documents.
It will ring once to alert you of an
incoming call, and then starts receiving.
3. Auto Select
- In this mode, the machine rings a
number of times. You can answer
the call while the machine is ringing.
If you do not answer the call,
the machine automatically changes
to receive fax messages.
Jul 11, 2009 | Ricoh Office Equipment & Supplies
Fax not received
No, just the fax phone number.
Mar 09, 2009 | Ricoh 3310Le Fax Machine, FAX3310Le...
Clear a Ricoh Fax 2000G Memory
    1. If your documents have already been scanned into memory:
    2. touch the [Change/Stop TX File] key
    • check that the [Stop Transmission] key is selected
    • touch the file that you want to stop, then touch the [Stop Transmission] key in the confirmation dialog box
    • touch [Exit] to return to the Fax Mode display
    1. If your documents are being transmitted:
    2. press the red [Clear/Stop] key
Dec 22, 2008 | Ricoh 2050L Laser Fax
Red light lit next to wrench icon on top panel.
Tell me yours e-mail address and i will sent you the manula the red lit may be a toner end lit
Nov 12, 2008 | Ricoh FAX2500L Plain Paper Laser
Erased files
the problem is the fax that are stored in memory you will lose anyway.
you will need to do the following to get rid of your error:
DATA REGISTRATION button,
and # button, on the operation panel
go down to number 8
then scroll round to ALL
and then restart the machine and the fault should go.
Hope this helps
Oct 23, 2008 | Canon FAX-L800 Plain Paper Laser
Ricoh aficio error message 06-06 page not received
its a fax error that states there is a line problem, problem is probably static in the phone line
Feb 18, 2008 | Ricoh Aficio 1515F Plain Paper Laser Fax
Receiving faxes but a weird noise
GO TO RICOH REPRESENATTIVE...TO FIX THE PROBLEM
May 31, 2007 | Ricoh FAX2050L Plain Paper Laser
Fax Machine
Although I could not find the manual for your specific model, go to the following site and download the manual for a model similar to yours. http://ricoh-usa.com/downloads/manuals.asp Similar models in the same family will generally use the same programing conventions. Pay particular attention to the RTI, TTI and CSI functions. Let me know if it was successful Ed
May 30, 2007 | Ricoh FAX3900NF Plain Paper Laser
Ricoh Aficio CL2000N Laser Printer Logo
208 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
