Toshiba Satellite  A135-S4527 PC Notebook
Problem for Toshiba Satellite A135-S4527 PC Notebook
Can not get the mouse to work the touch pad is not
By gillooley on Nov 02, 2009
can not get the mouse to work the touch pad is not working
Solution #1
posted on Nov 05, 2009
Not Rated)
clos3068
Rank: Guide
Rating: 0%, 0 votes
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Your mouse might be disabled; check its settings on the control panel; when you open the control panel you should have an icon for the mouse; when you open it there is a tab for TouchPAD ON/OFF.
Was this helpful?
Yes
No
Solution #2
posted on Nov 02, 2009
Not Rated)
georlin_cip
Rank: Guru  Computer Hardware  Expert
Rating: 88%, 32 votes
Hi, first test with an external mouse, and then check your device manager, you can get there from control panel, system, hardware tab, device manager button. If there doesn't look like there is any anomalies you are going to want to check the bios peripheral device section to see if there is any options for mouse, probably will not be, bios is either F2 F1 or Delete. After that reseating the touchpad would be a good idea, sometimes it just gets loose, unfortunately you will probably need to call up a tech, as it will need to be taken apart. If all fails then it will just need to be replaced, the touch pad comes as a single part you buy with the top plastics that go around the keyboard. Suggest using model of laptop and brand when you search and to use www.froogle.com if you can, it will be cheaper.
Was this helpful?
Yes
No
Popular Solutions for Toshiba Satellite A135-S4527
Questions and Unsolved Problems for Toshiba Satellite A135-S4527
Do you recommend Toshiba Satellite A135-S4527 PC Notebook?
Answer
Answer
Computer has Bluetooth Stacks for Toshiba program and I have a printer with a blutooth adaptor that... (More)
Answer
satalite pro m50 .i seem to have lost the sound !!
Answer
when trying to install driver I get this message: "The filename, directory name, or volume... (More)
Answer
I am looking for the wiring diagram or at least a hand installing of a toyota AM/FM reciever 36202 I... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top PC Laptops Experts
Top Computer & Laptop Repair
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
