Question about Maytag Atlantis MDE7400AY Electric Dryer
TUMBLE DRYER BELT
PLEASE HELP I HAVE ORDERED A NEW TUMBLE DRYER BELT AS MY OLD ONE SNAPPED BUT HAVE NO CLUE HOW TO PUT IT IN I HAVE A WHITEKNIGHT MODEL CL372WV, 1400W HEATER AND 200W MOTER, PLEASE HELP.
  • angielondon Jan 07, 2008
    I do too... mine is an Indesit ISV60S can u help?
  • 283 Answers
The topic heading said Atlantis MDE7400AY Electric Dryer Was this misposted?
Posted on Jan 03, 2008
Can anyone help me plz, i have a 37AW white knight dryer,my partner slammed the door too hard and the dryer hasn't worked since, has anyone got any ideas how to fix it, or tell me what to look for?
Probably broken the door switch which stops the drum when the door is opened. It may even just be the nylon strike pin that presses the switch.
White Knight 37AW Tumble Dryer Spares ' White Knight Spares
https://www.whiteknight-spares.co.uk/tumble-dryer/37aw/catalogue.pl?path...ref...
White Knight 37AW Energy Saving Tumble Dryer Balls. 4. 37 Reviews ... White Knight 37AW Switch Strike. Genuine ... White Knight 37AW Spring For Door Latch.
White Knight 37AW Tumble Dryer Spares - WhiteKnight-Spares, Parts ...
https://www.whiteknight-spares.co.uk/tumble-dryer/37aw.../catalogue.pl?path... White Knight 37AW Energy Saving Tumble Dryer Balls. 4. 36 Reviews ... White Knight 37AW Switch Strike. Genuine ... White Knight 37AW Door Window - Clear.
White Knight 37AW Tumble Dryer Parts ' Partmaster
https://www.partmaster.co.uk/tumble-dryer/37aw.../catalogue.pl?...whiteknight... White Knight Tumble Dryer parts - repair your White Knight Tumble Dryer with a ... White Knight 37AW Switch Strike ... White Knight 37AW Spring For Door Latch.
37aw white knight dryer door switch Google Search
Jun 06, 2018 | Dryers
Kenmore ele. Dryer 110.69522800 not blowing anymore, still tumbles and heats but no exhaust being put out, help!
First, open the unit and check to see if it is clogged with lint. If the unit is tumbling, then it should blow since the belt also runs the blower. If the blower is broke, here is the new blower to order.
Nov 22, 2012 | Kenmore Dryers
How do i replace the belt on a White Knight 427WV tumble dryer
There should be a access panel at the back of your dryer.
Take it off and flip the belt onto the motor pulley. Good Luck.
Dec 02, 2017 | Dryers
I need help to fit a new belt to a whight knight cl372wv tumble dryer..plse help .i have taken the top off and also the back but just can't see any way in
It is usually the front that has to be removed. Then you can see how the belt can be placed around the drum and accesssed at the bottom in order to be connected th e the motor pulley. The front usually has a small bolt/screw at the top (inside) that connects it to the side panels. There could also be 2 screws at the bottom (on the outside) for some models. make sure the electric is unplugged and you will need to disconnect the doorsitch wires. The next trick is to know how the belt orients itself around the idler wheel before it attaches to the motor pulley wheel. If you knoe this, great, but if not, it can be frustrating. Perhaps there is a diagram on the inside of the front cover. Just remember that the idler wheel arm must be bent with tension so that the wheel is close to the motor pulley when the belt is applied and finally in place. Goodluck, macgivor
Jan 02, 2010 | Dryers
How to fix a belt on zanussi tumble dryer model number zdc 46130s
heat elemet works, drum will not tumble. Help. Little odl aldy, Rosemarie
Jan 25, 2009 | Dryers
I have a WhiteKnight CL43 tumble dryer. The drum will not turn without first being turned by hand before quickly closing the door. It will then continue until its time for the drum to reverse and it stops...
Not all that familiar with the Whiteknight dryer series but a dryer is a dryer and your problem sounds like it could be narrowed down to a few things. Based on your description of the problem and without knowing how much use that dryer has been subjected to, it sounds like you have a belt slipping ..or if it is configured like many other dryers..there may be a belt tensioner that came loose. In either case, the drive motor pulley spins andthe belt doesn't have enough tension or friction on the drum to rotate it. You might try cycling it without clothes to see if it spins up... if it does spin ( without assisting it) then once you add the weight of the clothes it doesn't have enough friction to spin the drum. Hope that helps !
Aug 07, 2008 | Dryers
Changing belt
ok hi pretty lady
ok back to dryer, belt go's around drum and tension pully at bottom then to the electric motor
Jan 20, 2008 | Dryers
Insalling a tumble dryer belt
The top of dryer hindged, snap clips in front, pop clips with scewdriver, front panel should slide up and out or tec scews along inside edge, motor should be on your right side facing drum, motor bolted to botom plate, need to check belt tennsoiner for any type of wear and damage,the rest should be simple,re-assemble dryer.
Jan 03, 2008 | Dryers
Maytag Atlantis MDE7400AY Electric Dryer Logo
153 people viewed this question
Top Maytag Dryers Experts
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
