Question about Maytag MER5770 Electric Kitchen Range
Maytag MER5770AAB smooth surface range infinte switch has failed What are the minimum number and location of screws that need to be removed to access the switch within control panel? all part diagrams I have found on websites do not show screw detail and I always seem to end up deconstructing 1/2 of appliances before I figure out which are the few simple screws that required removal. Thanks
  • obeguy May 13, 2008
    same question for kitchenaid kerc506hbt-1
  • 906 Answers
Good day,
hope this link below will solve your problem.
kitchen appliances
Posted on Jul 31, 2010
Broke Range Surface Element Control Switch (1st position from left) on Bosch electric range (HES7282U-05). Looks like glass cooktop needs to be removed to access. Please advise. In advance, Thanks
TURN OFF POWER
pull knobs and dials off
open oven door look under console remove toex screws in lower console(control panel)
the front panel glass will drop out
you can know see a metal panel that surface switchs mount too
the screws that hold panel are around the edge the screws that hold cooktop down should be able to be seen
you do not have to remove the cooktop to replace switches
but once the front screws for cooktop are removed the top slides forward and lifts off there will be 1 ground wiire to disconect from cooktop if you do put it back
gl
Sep 15, 2018 | Bosch Kitchen Ranges
I HAVE A MAYTAG ADVANCED COOKING SYSTEM MODEL NUMBER MER5770AAB WITH CODE F9 WHAT DO I DO TO REMOVE CODE ?
That code indicates a problem with the oven door Lock Assembly. If nothing can be found wrong with the door lock, then the electronic oven control would need to be replaced.
Sep 28, 2017 | Maytag Kitchen Ranges
BURNERS KEEP IGNITING
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
Jul 30, 2011 | Maytag MER6772 Gemini Electric Kitchen...
How do I access a spark ignitor on a Viking gas
I am assuming your referring to the stove top burner ignitor. Well - I can only say on my Viking 48 inch - it was located at top RHS of the stove on the 'back wall'. I was advised by a 'tech' that it would be located at the back of my stove (ie he would have to pull out the built in unit and would cost me 500$). In fact I replaced the unit in 30 minutes ... I removed the two RHS burners (one screw each), disconnected ignitor wires, removed the bracket holding the burners (one screw), followed ignitor wires to silver box covering the ignitor unit (2 screws), opened it & replaced ignitor. Forgot to say - 1st thing I did was turn off power & gas to the range. Of course you need to ensure it is the correct one for your stove. The ignitor you remove should have a manufacturer part number on it. No calibration required on mine - a sealed electronic unit. Probably about 10 wires that need to be R&R'ed - they are on with reuseable fasteners.
Jan 18, 2010 | Stoves 600SiDOm Gas Kitchen Range
F1 on the read out comes up and the oven well knot work it keeps comeing up f1 on read out it is a maytag rang mer5770aab sel.no.13196174uu
Hi martysherrip,
The F1 fault code description is a defective touch pad or clock (ERC). Please refer to the steps below for additional information.
1. Unplug the range power cord or turn the power off to the range at the circuit breaker. It is very important that the power to the range has been disconnected, so please double check before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back.
7. Please replace the ERC, if F1 comes back. If it does not, replace the touch pad.
Hope it helps.
Thank you for using FixYa.
Jan 02, 2010 | Maytag MER5775Q Electric Kitchen Range
Oven door won't open
The micro switch in the latch has failed.
You must turn off the gas supply.
Remove the screws from the surface burners.
Raise the lid to access the door mechanism to open the door and to replace the switch.
May 23, 2009 | GE Profile Spectra JGBP79 Gas Kitchen...
Replacing smooth top
Have you purchased a new top yet? If you haven't, you can find it at repairclinic.com for about $270.00 (item #703866). Just type in your model number in the search index and you will find a pictorial part index for your range. The part isn't cheap, but it would potentially cost you twice as much to have a repair service replace it for you. If you still wish to pursue this repair, follow these simple instructions:
1. First of all, UNPLUG the range before servicing. There are dangerous voltages still present even with burners turned off.
2. Secondly, is the glass top still intact? I know it is broken, but is the glass completely busted apart, or is the top just cracked? If it busted, you will need to get rid of a much of the glass shards as you can and thoroughly vacuum the area around the oven box. Use extreme care when handling broken glass. Wear safety glasses and gloves.
3. There are a few screws located under the front edge of the cooktop. You will need to open the oven door to see them. Remove these screws and the top should lift up. If the range is not equipped with any kind of hinge supports, the top will have to be propped up.
4. On some ranges, there is a disconnect plug for the surface element wiring harness. If you have this feature, unplug the cooktop and leave the elements in place. Place the whole assembly face down on a soft surface (like some old towels, or a blanket) and remove the surface element assembly leaving all the elements wired together. Place the new cooktop face down in the same manner and lay the surface element with wiring harness directly on to it and screw in place. Install the new cooktop back on the range and you are DONE.
5. If the wiring harness does NOT unplug, there are a series of screws holding the element assemblies in place. Leave these assemblies wired together for ease of replacing. It is recommended that a second person holds the assemblies in place to support the wires until all the screws have been removed.
5. Lay the intact element assembly, with wires still connected, on top of the oven box handling the elements with care. they are very fragile. Care also must be taken not to handle the element coils or ceramic material. Try to handle from the underside of the element only. Oil from your hands can cause damage to the element and/or premature failure. If you have to remove the elements, individually, make sure you write down how the wires were connected to ensure you reconnect them in the right order. Make sure you also take note of the numbering scheme on the element and make sure you place the mounting brackets in the same holes that they came out of.
7. Use care when screwing into the new cooktop. CAUTION: The scew holes are usually painted and a little force may be required to thread the screws. Do not apply too much pressure on the glass, or you can damage it. Prop the new cook top in place and install the surface element assembly from underneath. A helpful hint: Use some duct tape to hold the assembly until you have screwed it back into place. Don't forget to remove the duct tape when completed.
Good luck and I hope this helps.
Feb 11, 2008 | Maytag MER5770 Electric Kitchen Range
One of my burners is out, and I do not know how to get under the cooktop
You can check the element from the switch on the control panel. Unplug the oven, remove the back and put an ohm meter on r1 and r2 terminals to check resistance. If it shows open then the element is bad. If it shows resistance then replace the switch. To remove the top there should be screws under the front part of the top which you can see when you lower the door then just lift up. You won't be removing just the glass.
Sep 23, 2007 | Frigidaire FEF365AS Electric Kitchen Range
Maytag MER5770 Electric Kitchen Range Logo
240 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
