Question about Samsung Ultra Smart F700
F700 ringer vol
Fab phone.. but how do you turn the ringer volume up
  • alexh Jan 04, 2008
    iv gt the same problem iv turnd it up on my profile but is still very quit have u susted it yet
  • Anonymous Jan 17, 2008
    i also have the same problem but i am not sure whether it is possible 2 change the volume outside of the profiles...this is a serious problem because if u r in a busy public place u will b unable 2 here ur phone ring...I also hav another problem wiv this fone...i hav filled my 1gb memory card wiv music but whenever i go 2 albums or artists the phone crashes and resets itself which means the only way i can listen 2 tracks is 2 listen through them all or skip thru them
Really?? Mine is loud as hell I heard it ringing in my coat across the room
I think there is a way to change the volume but the button on mine doesn't seem to respond to touch When you first turn on ur screen there should be a lil bell in the top left corner Ive gotten it to work once It turned my phone silent but other than that it doesnt respond Ive tried using it while the keyboard was out to get it to switch sides but still no good You can try playing with that otherwise we'll all just have to make that long trip to profiles just to turn our phone volume up and down
Posted on Mar 01, 2008
Turn ringer on
To set the Vtech T2326 ringer:
there are only four ringer tone/volume choices plus "off" available
1. Press the PROG end of the "SELECT/PROG" rocker switch.
The display will light and show "DIRECTORY"
2. Press the right side top button "VOL +/DIR"
The display will change to "SPEED DIAL"
3. Press the right side top button "VOL +/DIR" again The display will change to "RINGER: [number] ( 1 - 4 or OFF )"
4. Press the SELECT end of the "SELECT/PROG" rocker switch.
The "RINGER: [number] ( 1 - 4 or OFF )" will blink and the ringer will sound.
5. Press the right side top button "VOL +/DIR" The display will change from "RINGER: 1" to "RINGER: 2" and the sound will change accordingly.
6. Press the right side top button "VOL +/DIR" again. The display will change from "RINGER: 2" to "RINGER: 3" and the sound will change accordingly.
7. Press the right side top button "VOL +/DIR" again. The display will change from "RINGER: 3" to "RINGER: 4" and the sound will change accordingly.
8. Press the right side top button "VOL +/DIR" again. The display will change from "RINGER: 4" to "RINGER: OFF" and the sound will cease accordingly.
9. Press the right side top button "VOL +/DIR" again. The display will change from "RINGER: OFF" to "RINGER: 1" and the sound will change accordingly.
10. ...and so on, cycling through the four choices & OFF: when you decide to select one, press the "SELECT" end of the central "SELECT/PROG" rocker switch.
11. The display light will go out, the phone will chirp in acceptance, and it will be ready to use the chosen ringer. --
Sep 07, 2013 | Vtech T2326 Cordless Phone
Need ringer on uniden ex14246
With the phone in standby mode (not talking, not doing something in the menu, etc), press vol-up or vol-down. The phone will sound the different ring tones at different volumes. To turn the ringer off,
select "Ringer Off". When the phone sounds the ring tone and volume you wish to use, press the end key.
Oct 14, 2011 | Uniden 2.4 GHz Cordless Phone System
Volume on G E model 21028GE3-4
To adjust the speaker volume, press up/down on the base unit.
To change the ringer volume:
Make sure your phone is OFF (not in talk mode).
Press the MUTE/PROG button to go to the main menu.
Press CID/VOL (up or down) button to scroll to "HANDSET SETUP".
Press MUTE/PROG button to confirm.
Press CID/VOL (up or down) button to scroll to "RINGER VOLUME".
Press MUTE/PROG button to enter the menu. "SET RINGER 1HI 2LOW 3OFF" shows in the display.
Use the touch tone pad on the handset to select 1, 2 or 3, or use the CID/VOL (up or down) button to scroll to your selection. HI is the default setting.
Press the MUTE/PROG button to save your selection. You will hear a confirmation tone and the new volume setting shows in the display.
To change the receiver volume: When the handset is ON (in talk mode) you may adjust the receiver volume by pressing the CID/VOL (up or down) button.
If you need a manual, you can download one here.
Oct 06, 2011 | GE 21028GE3 Cordless Phone
I have Uniden DCX700 phone- how do I turn the ringer on and off?
The DCX700 is an expansion handset for several different Uniden phones (DCT746, DCT748). To change the volume of the ringer, press the Vol + or Vol - button with the unit in Standby (not making calls). There are three ringer volumes: Off, Low and High. Pressing the Volume buttons will let you cycle through the list. The volume buttons are to the left of Talk below the LCD screen.
You can temporarily mute the ringer by pressing Mute while the phone is ringing.
The manual for the DCT746 is here: http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/DCT746Mom.pdf . All Uniden cordless phone manuals are available in numerical and alphabetical order here: http://www.uniden.com/scat/cordlessphones_mnl . The manual for the DCX700 handset (with registration information) is here: http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/DCX700om.pdf .
I hope this helps.
Sep 21, 2011 | Uniden DCX700 2.4 GHz Cordless Phone
Phone does not ring on incoming calls. The manual suggests "make sure ringer is on." Where is the ringer?
Ringer On/Off and Ringer Volume 1. Make sure your phone is in idle mode. (not in Talk mode) 2. Press the VOL (- or +) button to activate the ringer volume setting. 3. Press either the LINE 1 or LINE 2 Soft key to select the desired line. 4. The LCD will display the volume range and currently-selected volume in an ascending series of bars. 5. Press the VOL (- or +) button up or down to increase or decrease the volume in steps. 6.The system will retain the last entry, it is not necessary to save or acknowledge your selection from this mode.
It is also possible you have set the DND (Do Not Disturb) feature which will also caution your phone not to ring when a call comes in.
Have a great day. Hope this helps.
Jul 05, 2011 | RCA ViSYS 2-Line Speakerphone
Uniden Model EX 14560 Ringer off How to put ringer on
Here some solutions for your problem + a link to the user manual.
**Selecting the Ring Tone and Volume
Your phone has five different ringer tone/volume combinations you can choose from.
To select the ringer:
1) With the phone in standby, press [vol/ / ] or [vol/ / ].
2) The phone will sound the different ring tones at different volumes. To turn the ringer
off, select RINGER OFF.
3) When the phone sounds the ring tone and volume you wish to use, press [end].
**Temporarily Mute Ringer
If the handset is off the base while an incoming call is ringing, simply press [end] to mute
the incoming ring. The ringer will sound with the next incoming call.
Note: You can only mute the handset ringer if the handset is off the base when the phone starts
ringing.
Adjusting the Earpiece.
**Here is also a link to the phone manual http://www.uniden.com/pdf/EXI4561om.pdf
May 18, 2011 | Uniden Cordless Phone
How do I turn the ringer on? 5.8 EXI 5160 phone
Handset ringer tone and volume
Press the volume up key or volume down key (labeled as
vol or vol) in standby mode to select one of five
ringer tones and volume combinations.
You can get the manual on link below page 19 will tell you how to set ringer volume.
http://www.uniden.com/pdf/EXI5160om.pdf
Dec 23, 2009 | Panasonic 5.8GHz Cordless Telephone
How to turn the volume up?????
There are 2 type of volume: Speaker volume and Ringer volume.
If u mention about Speaker vol, then while the phone is in hands-free conversation mode, press up (/\) or down (\/) key.
If u mention about Ringer vol, then while the phone is receiving a call, press press up (/\) or down (\/) key.
YBC (/\)
Jul 05, 2009 | Panasonic KX-T7633 Corded Phone
I dont know how to adjust the ringer volume
The manual is available for free download from www.manualslib.com
A Google search on "vtech t2326 manual" will take you right there .... follow their site instructions,
enter the "spam protect" numbers and choose "download the .pdf file" Be careful of clicking on the
advertising that might take you into strange areas for other purposes.
3. Press the right side top button "VOL +/DIR" again The display will change to "RINGER: 1" ( or "RINGER: 2 or : 3 or : 4 or : OFF" )
10. ...and so on, cycling through the four choices: when you decide to select one, press the "SELECT" end
11. The display light will go out, the phone will chirp in acceptance, and be ready to use the chosen ringer. --
To preload names & numbers into the DIRECTORY is a bit more arduous but not difficult; there is
a limit of 10 entries after which attempting to add another will result in a "MEMORY FULL" alert
being shown. Hint: during name entry, the "VOL -/CID" button will backspace/erase letters and the
"VOL +/DIR" button will enter blank spaces. Letter selection is familiar to text messaging ie, the letter B
is a result of "22" being keyed, the letter R is "777" etc.
Good luck !
Jun 08, 2009 | Vtech T2326 Cordless Phone
How is ringer volume adjusted?
VOLUME
While talking, press the VOLUME buttons (left and right
arrows) to control the volume of the handset's earpiece.
There are four volume levels. Press the right arrow (+)
button to increase the volume level, and press the left
arrow (-) button to decrease. VOL 1 is the lowest level and
VOL 4 is the loudest.
Jan 02, 2008 | GE Cordless Phone 900 MHz
Samsung Ultra Smart F700 Logo
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
