washer makes loud clunk as it goes around. tub feels very loose. front load Gallery. I thought something in between tub and shroud but nothing. I think tub is loose.
it sounds like you have a broken spinner assembly,
this is the unit that connects your innur tub to you center shaft seal,,,,
it can be replaced and repaired by you no special tools but the cost could be quite extensive....
an outer tub and spinner is an absolute minimum and there are parts to inspect as you take it apart
do you need both halves of the outer tub would be the biggest one
unless this machine is less than just a few years I would just not bother putting the money into it
its well past cost effective 500.00 for the two parts ive mentioned
Was this helpful?
Yes
No
3 people thought this was helpful
Popular Solutions for Frigidaire Front Load Washer
Model LTF2140ES1. Did not go into final spin to wring clothes of excess water. Was not...
(More)
Model LTF2140ES1. Did not go into final spin to wring clothes of excess water. Was not out-of-balance. Did not beep "error codes." Suggestions as to the problem?
My machine was in mid-cycle and it just stopped working. I have power to the machine and all of the...
(More)
My machine was in mid-cycle and it just stopped working. I have power to the machine and all of the buttons work, but when I start any cycle, nothing happens. We had a service call and they thought it was the door latch, but it still doesn't work.
start a load and it will pause several times during a cycle over and over. Washer is level and...
(More)
start a load and it will pause several times during a cycle over and over. Washer is level and hooked up correctly
