My daughter just moved into a new house that has an older Jenn Air E33658 electric glass top range that I believe is downdraft and has a convection oven. I can not figure out how to run the self clean oven and would like to get an owners operating manual
Hello. I can assist you. The model you have is indeed an older model and the manual is not available through the normal internet channels. However, contacting Jenn Air directly should allow you to get the manual you need at no cost. Here is the contact information: http://www.jennair.com/flash.cmd?/#/page/contactus/ Just go to that address and you will have Jenn Air phone numbers, email, fax info and mailing address. This is an excellent company and they will help you get the manual you need. That said, the self clean oven will come on when you set both the starting time and the ending time on the range. If it has a manual lock on the oven door, lock it first, if it has no lock the door will lock and unlock automatically. Generally setting it to clean for three hours is a good clean. enn-Air Brand Home Appliances Customer eXperience Center 553 Benson Road Benton Harbor, MI 49022-2692
I have a dual range, with an electric oven and the fan won't turn off. The oven has completely...
(More)
I have a dual range, with an electric oven and the fan won't turn off. The oven has completely cooled down, days ago.
Jenn-Air Radiant Element Range 8101P368-60 Left Front inner element stopped working. Seems to get...
(More)
Jenn-Air Radiant Element Range 8101P368-60 Left Front inner element stopped working. Seems to get slightly warm, however no red glow. The outer ring works without the inner ring. The hot light does not work in either the inner or outer position. Appreciate any input.
my Jenn Air range (47600W) fan will not turn on. I replaced the blower motor months ago and...
(More)
my Jenn Air range (47600W) fan will not turn on. I replaced the blower motor months ago and confirmed that wasn't what went bad. When I push the fan button it beeps, but the fan does not kick on. Is there a relay or module which controls the off and on function of the fan?
