Question about Goodman GMS90703BXA Heater
Explosive Ignition When my LP gas heater lights, I hear the ignitor click and that is followed by an explosion rather than a smooth ignition in the burner area. This explosion varies in relation to how long it is between ignition cycles. The longer the time the greater the bang. I do not smell any gas when the heater is not operating so I do not think this is a leak that allows accumulation in the chamber but rather a failure to ignite when the main gas is first released. Ideas?
  • Anonymous Mar 13, 2014
    Igition time for the gas is taking too long, Accumulation of gas is creating too big flame when igniting. This might creat an explosion some days.
    Thanks to advise
  • 1,420 Answers
Check the alignment of the igniter to burner. It should be in the flame of the burner but to one side or just below. Does the igniter glow about 15 seconds prior to the gas valve opening or just a second or two. The igniter should glow 10-15 seconds prior. If the temperatures outside are unseasonably cold, you could be experiencing a gas regulator condition. If so, as the temperature rises, the condition would lessen. Call your gas company to get the regulator tested and gas pressure checked.
Posted on Jan 04, 2008
Ignition problems on model cf504c-h
Short pilot causing explosive ignition or burners out of line when lighting up
Feb 19, 2013 | Heating & Cooling
No ignition
Check this page its a discussion on your same problem. I think it can help.
regards
http://ask.metafilter.com/48886/Help-me-fix-my-heater
Feb 19, 2008 | Heating & Cooling
Gas oven will not light
Does it have Pizeoletric igniter? one that makes a clicking sound till the burners come on? If so check the ignitor and replace if required. Failing that I would call a gas technitian since you don'r really want to play about with explosive substances..hope this helps
May 02, 2012 | Whirlpool WFG231LVS Stainless Steel Gas...
Pentair minimax nt explosive ignition
Problem is an obstructed gas oriface. The burners light from the burner closest to the pilot assembly out like a dominoe effect. The explosion is because the gas has to make its way over to the pilot from a further burner thus filling the firebox full of gas before it ignites. This blockage is most commonly from a spider web inside the oriface itself. Pull the burner tray, remove the orifaces from the tray and look through each one cleaning them out with a toothpick from the backside. The orifaces should be threaded on the gas line coming off the gas valve (looks like a silver box inside the front panel)
Feb 16, 2012 | Pentair Minimax NT Heater
The ignitor starts but after a few seconds you hear a click and it goes off like gas valve shuts off.
You need to check the wire to the flame sensor. The wire could be bad or the connection on the end could be loose or corroded. You can get fire but if it dosn't read back to the ignition control, the control will think no fire and shut the gas off, (thats the click you hear) to keep it from building up and causing an exposition.
If the sensor wire is good, clean and tight. Then it will be the ignition control itself or the pilot isn't hitting the flame sensor.
Dec 01, 2010 | Jandy LAARS GAS VALVE ASSY.,LP ALL EXCEPT...
We believe we are to turn on the water electric button to start the heater. Directions say the light should go out when ignition occurs. It won't go out.
If your water heater has an electric element, as well as electronic ignition for gas operation, you may be getting them mixed up. One switch should show like a lightning bolt beside it,(that's for hydro use) the other will show a small gas flame beside it.(that's to turn on ignition for gas operation.)
If you only have one, my guess is it's for electronic ignition. When you turn that on, you should hear the water heater trying to ignite outside.("click,click,click) and then burner should ignite if you have your propane on. Get back to me with your model number of the heater, behind cover outside, and I can tell by that what you have as far as just gas, gas and electric, etc.
Apr 26, 2010 | RTO Atwood Water Heater - 6 Gal LP
The oven of maytag range mgr5775qdw poorly
The ignitors/burners need to be cleaned properly.
Build up of grease, dirt, rust, mineral deposits, etc can cause improper gas flow resulting in a delayed ignition. That causes a build up of gas and the delayed ignition ignites it all at once, and you have your WHOOMP mini explosion.
Sep 25, 2009 | Maytag Ovens
Electronic ignition tries to lite, clicks 5 times, then goes POOF
Gas burners go "poof" when they have too much gas in the area upon lighting. This is normally due to the ignition source not being close enough to the initial source of gas. This is normaally corrected by ensure the main burner is clean so that it distributes the gas correctly and having the ignition source at proper strength and location. I would have to have good schematics of your heater to be more specific. I hope this helps.
Sep 09, 2009 | RTO Atwood Water Heater - 6 Gal LP
I have a Frigidaire stove, when I turn the oven on the element lights up the smell of gas is real strong and then it lights and sounds like an explosion.
Have you spilt anything on the burner? If so it will need to be cleaned,you will need to do the following (you need a pin, a matchstick, a drinking straw and a torch):
Make sure the oven control and the electric isolated is off please, remove the shelves, using the torch, inspect the oven burner, if there is no apparent blockage, disregard the following advice and seek the help of a 'Gas Safe' engineer in your area.
If it is blocked,using a pin or matchstick clean the holes in the burner, and use the drinking straw to blow the debris away. Move away from the burner, and see if it lights.
If this fails to work it could mean that the ignition is in the incorret position allowing for explosive ignition. See advice from a 'Gas Safe' qualified engineer.
I hope this helps.
Jul 06, 2009 | Frigidaire FGB24T3A Gas Single Oven
Goodman GMS90703BXA Heater Logo
144 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
