Question about Sony KV-35XBR48 35" TV
Tv wont turn on
Tv shut itself off and will not turn back on by remote or buttons. fuse is ok. seems like no power to set
  • 579 Answers
How old is this set?
I guessing it is maybe 8 years? In that case I would plan on overhauling the high-voltage circuit because it is going to need it soon whether it is the problem now or not (and it very likely is). Should cost under $200 at a shop. I generally don't waste time on older dead TV's but this is a good model and worth the effort. The risk is that sometimes when the high-voltage fails, it blows up other circuits in the TV and can be a real nightmare.
Posted on Jan 03, 2008
My LG TV red light won't turn on. although the plug fuse and the remote OK
Try manually pressing the power/standby button on the tv (side or bottom) the red light should appear, most modern tv's will turn on simply by pressing the channel up or down on the tv itself.. But unfortunately in most cases, this seems to be an internal surge and needs a professional to inspect..
May 14, 2012 | LG 42PG20 42 in. Plasma HDTV
Tv just shuts off by itself
Don't use the power button on the t.v. itself to turn power on or off. Use the remote. The power button actually gets "stuck" and causes the t.v. to turn on and off, seemingly at its own accord. Make sure the button is all the way out and flush with the cabinet, then just use the remote to power on/off. Hope this helps.
Mar 28, 2009 | Samsung DLP HL-P5663W 56" TV
TV Won't power on
1. Check Power
2. Check Fuses
3. Check Relay
WARNING HIGH VOLTAGE: Do not attempt to work on your set unless another human being is present who is trained in CPR.
Thank you for selecting FixYa!
azkeyz@fixya.com
Wizard Division
Sep 24, 2008 | Televison & Video
Blinking red light standby/timer
It seems to respond to power supply, send it to a nearby technician. The problem might be it fused the picture power supply fuse. make sure the installation is at you presence.
Sep 06, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Remote was hit, shut set off, and can't get it back on. Sounds like timer is on.
First try turning the TV on from the Power button the set itself (assuming it has one).
If not, unplug the TV from the wall, wait a half hour, then plug it back in. It should come back on.
Also check that none of the buttons on the remote are stuck down, and that the batteries in the remote are OK. The toy might've stuck a repeating button down (like volume) which may have then drained the remote's batteries.
Apr 07, 2008 | Televison & Video
How to turn on Sony Trinitron without a remote control
Good day.
Please check with the channel buttons of your unit. They replace the power buttons functions.
chris
Mar 21, 2008 | Sony KV-27V40 27" TV
Assistant
check your sleep timer settings thats the most comman prob
Dec 18, 2007 | Philips 27PT81S 27" TV
EMERSON-MODEL#VT911OA-W VERSION-C
If the set will not turn on with the power button on the front of the set, you must then try turning it on with the remote. You must be sure that the remote is working correctly. If the set turns on with the remote, then your power button itself is bad or has cracked loose. This is easily fixed without having to replace the board. If the set does not turn on with a working remote, then something inside the set has failed and it should be serviced by a qualified tech.
Aug 20, 2007 | Emerson EWF2704 TV
Phillips 60'' projection hdtv wont turn on
Question do you see green led or light when pressing power button? If you can also listen for a high pitch noise coming from back of set. This would be an indication that the set has powersuppy problem or high voltage problems. If the set is dead and no noise then maybe fuse or open circuit.
Aug 13, 2007 | RCA P46924 46" Rear Projection Television
Televison & Video Logo
140 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
