Question about Linksys WPC54G Wireless-G Notebook Adapter V2.0 (WPC54C)
Won't load software properly
I have a Linksys WPC54G Wireless-G card connected to a dell latitude D600, running windows XP. After I plug the card in and proceed to the next step, Nothing happens. it should be taking me to the "available wireless networks" screen. but it doens't do anything. It stops there. I doesn't lock up it just stops loading. When i try to open the program only part of it works. i can't do anything with it ,all it does is "searching". I had this card on same computer running windows 2000 and it worked fine. what can i do to fix this problem? thanks
  • 1 more comment
  • raideral Jan 03, 2008
    Thanks Rikardo. It worked ! And now I am emailing you near a nice cozy fire instead of a cold dark room. You're the greatest. Thanks again.
  • Anonymous Jan 17, 2008
    notebook adapter cd only works up and till search starts then cuts out ive had this problem time after time with laptops
  • DennisMollet Jul 21, 2008
    The installation doesn't even work. Trying to install on Inspiron 1100 w/ Windows XP Home. I've used the CD included in the box. I've downloaded the driver from LinkSys. I've re-installed about 10 times, and it always either freezes the OS on install or fails to load the driver. Sometimes it prompts for a file that isn't on the CD. I've seen many people with the same issue... Very frustrating.
  • 4 Answers
Have you chcked if the system recognizes the card and installs the correct drivers?
Otherwise go to the linksys website and look for the xp drivers for your model and instal it?
Hope this helps
Posted on Jan 03, 2008
WPC54G wont install power light is on
The problem is that the PCI slot/socket where the wireless adapter is snapped/connected is not not compatible with the adapter. I suppose that the adapter is more more faster than than socket so it can hardly function as it should. I recommend that you return the adapter and get a slower version of the adapter. Make sure that the drivers are properly installed by removing/uninstalling any previous software from the system.
Apr 28, 2009 | Linksys WPC54G Wireless-G Notebook Adapter...
Need WPA2 wifi connection to my Linksys with Dell D600
The WPA settings on your wireless card must be the same as the setting you configured on your wireless router. This allows your wireless card to communicate with the wireless router.
Apr 07, 2009 | Dell Latitude D600 Notebook
Connecting lap top to internet
Try to connect with wireless lan to linksys router. first u shuld check ping the ipaddress of linksys router with laptop
Feb 21, 2009 | Dell Latitude D600 Notebook
Dell Latitude C640 get slowly (CPU nearly 100%) when install wpc54g
Well yes and no. Yes you can uninstall the software but then you will not have any wireless connection. Unless you are going to replace it with something else.
Oct 03, 2008 | Dell Latitude C640 Notebook
Bad Wireless Connection
This is usually caused by a driver glitch. From the device manager, uninstall the drivers for the wireless, then reboot. The machine will find and reinstall the drivers. If the problem persist, the take the card out, clean the connections, and reinstall it. It's located under a panel on the bottom of the machine. If it still won't work, then you need to replace the wireless card.
Jun 26, 2008 | Dell Latitude D600 Notebook
"WPC54G is not installed"
Those install programs that Linksys uses are terrible. This happens all the time.
You probably can't use the linksys program to install the software on a Windows 2000 machine you should be able to install just the driver you need. I have never used wireless networking on a Win 2000 computer before. Win XP has sotware already built into the operating systems to deal with wireless networking.
Uninstall all Linksys wireless networking software. Restart you computer with the wirless network card install and let Windows search for the correct drivers on the CD.
Jun 22, 2008 | Linksys WPC54G Wireless-G Notebook Adapter...
Your did not provide any info on which card you have or wish to install; USB, PC Card, or internal mini PCI card.
For mini PCI cards, first you have to open up the D600 laptop and install the Hardware (ensure to connect the antenna cables) then power-up and install the software (drivers and utility).
For USB and PC Cards, follow the device manufacture's recommended steps. Generally, for USB devices, the software (drivers and utility) needs to installed first before the hardware is connected.
If you have successfully installed the hardware and software (driver/utility) you can scan, choose and connect to an available wireless access point or wireless ad-hoc setup. This can be done through the wireless manufacture's utility or from Windows Wireless Zero Configuration utility. If you use the manafucature's utility, Windows Wireless Zero Configuration utility will not work; will not scan or list available wireless network.
Check "Dell Connect To A Wireless Network" article
May 07, 2008 | Dell Latitude D600 Notebook
Dell D600 - Linksys wireless router/adapter
Seems there is a problem with the Linksys since there is not any lights coming on. Did you plug it into a switched outlet in the wall? Does it work if you plug the Linksys into an outlet in another room?
If you can get it to light up, the way you will access it is through your web browser. Type in into your web browser and a login in screen should pop up.
Apr 28, 2008 | Dell Latitude D600 Notebook
Compaq Evo with wpc54g v.1 wireless adaptor
-- make sure that the wireless settings of your router match the wireless settings if you are using the utility of the linksys adapter
-- make sure also that you dont have any firewall or any security on your computer
-- you may also try disabling the adapter wireless utility and use the wireless xp zero configuration instead.
Apr 12, 2008 | Linksys WPC54G Wireless-G Notebook Adapter...
Open Questions:
Linksys WPC54G Wireless-G Notebook Adapter V2.0 (WPC54C) Logo
141 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
