Question about Hunter 20531 Vista Brushed Nickel Ceiling Fan
Light trouble fan works but the light does not turn off or on with the remote? is ther anything I can check within the fan like a fuse maybe gone bad?
  • mikeyh02 May 22, 2008
    The remote quit working after 6 months. NO lite control but 3 speed fan on/off/reverse controls still work. Have to turn on wall switch ( installed with new handicap bedroom) but this turns on light AND fan power.Cannot keep fan "ON" without light "ON".
    I think the remote is O.K., the trouble seem to be in fan body, ie. receiver control module for light. Unit will be 1 year old in Aug.
  • ANGLES May 27, 2008
  • 579 Answers
Believe it or not (It is a sign of our times), these fans have a computer chip in them and yours is probably gone bad. As with all appliances with computer chips, they really need to be plugged into an outlet with a surge supressor on it. (course they didn't tell you that.
To fix it, you have to replace the internal circuit board from the fan maker.
Posted on Jan 03, 2008
No power to cooker hood
Should be on a separate breaker, sometimes wired to a clock/fridge circuit. Check all breakers. I have seen people wire them to a GFCI outlet as well, not supposed to, but people still do it. Check for 120Vac at the fan and light switches, if its ther your switch is bad, it not there cicuit is not connected to power supply.
Aug 25, 2014 | Ovens
Ceiling fan light delay
How do you change the speeds? Pull chain ,dual control on wall or remote.
Sep 15, 2013 | Hampton Bay Dryers
2006 Harley flht speedometer and tach quit, all gages quit Neutral light, gas gage, low fuel yellow light none of them work. The red security light is on and it will not output trouble codes (hold speedo...
Sounds like a fuse has gone. Check all fuses. Then find out why it blew. If not fuse, then check and trace power on all orange/white wires in fairing.
Sep 05, 2013 | Harley Davidson Motorcycles
Minka ceiling fan
Replace batteries in remote,if still not working,go to fuse or breaker box and see if fuse or breaker switch is off or fuse blown,if good there,then it could be a bad switch on fan or remote is bad.If switch is bad,turn power off at box,remove, take to Home Depot or Lowe's and match up.
Nov 20, 2012 | Minka Dryers
I bought the ceiling fan with the remote control.I can get the lights to work off the remote control but not the fan. I have uninstalled ,installed the wiring3 times and can not get the fan to work.
the electronic control unit in the fan may have gone bad. It may not be fixable. or something in the fan's motor might have burn't out or shorted. If you like the fan alot, you could just tear it apart and just hard wire it into the house's electrical system. I don't know how well you are with electrical work like re-wiring things, but that's what I would do. but check to see if anything is shorted out inside the fan first.
Aug 12, 2010 | Hampton Bay Dryers
I have a Hampton Bay Midili fan which I just installed about a month ago and it was working fine. A few days ago when I flipped the switch on the light flickered on and off consistently until I turned the...
in many of these remote controlled lamps you cant use the new spiral light bulbs .. you can only use standard incandescent lights .. if thats not the trouble then you may indeed have a bad controller (in the fan) .. there is probably at least a 90 day warranty maybe as much as 3 years .. make sure the wire nut power connections are secure inside the fan.. if one of the the wires in the fan are not making contact then you will see a similar problem .. once in a while i have seen strong external RF signals interfere with the controller but thats rare and usually doesnt last long ..
i would : 1. check all the connections .. 2. replace the light bulb to make sure its not flakey or the wrong type .. 3. try to get the fan replaced in warranty ..
Jun 06, 2010 | Vacuums
Hampton Bay Fan will not turn on.
on some you hold down a button on the remote control while you turn power on .. you keep the button pressed for maybe 20 seconds .. i dont remember what button but probably fan on or light on .. the receiver acquires the code from the remote .. if you still have trouble i can probably find the specific instructions ..
Jun 05, 2010 | Hampton Bay 54 In. Dawson Ceiling Fan in...
The fan works but the light won't?
The electric outlet box in the ceiling (is there only one black and one white wire to be connected)? If so, you have to connect the black and blue wires from the fan to the black house wire. If you know this is already done, you next have to check the connetor from the light assembly to the connector of the fan unit ( that these coneectors are properly fitted). If this is ok , then the final item to check would be the pullchian switch for the light. Over-ride this switch (jump its connection) to see if light works, or take the light unit and apply ellectric to itfrom an extension cord (after you remove it from fan unit). Then you will know if wire connections within light are ok. All this assumes ther fan is not controlled by electronic remote control. If you have a remote control, thenit could be the circuit broard within the fan that sends a signal to the light. Good Luck, Macgivor
Oct 11, 2009 | Hunter 20763 52'' The Stratford II Ceiling...
Fan stopped working and light now only works on pull chain
there should be a remote inside of the fan that probably went bad
Sep 05, 2009 | Hampton Bay 24750 Huntington III Ceiling...
Ceiling fan remote not working
It is certainly possible that the remote went bad -- after all, it is an electronic device, and is was "made in China". With that said, there are other possibilities:
* The receiver, which is what receives the signals sent by the remote control, could have died. In most remote-controlled fans, the receiver is located in the ceiling canopy (the decorative part up by the ceiling, which hides the wires). In other fans, it's located in the switch housing (the part of the fan to which the light kit attaches). Solution: try everything else on this list; if nothing works, replace the receiver. Universal replacements for most models are available at Home Depot and Lowes.
* A wire on that receiver could have come loose. Solution: check all wires for secureness.
* A wire in your wall or ceiling -- the wire which provides power to the fan -- could have come loose or been chewed through by a rodent. Solution: use a circuit tester to check whether there's power at the connections at the top of the fan, in the ceiling, where the fan connects to the building's wiring.
* A circuit breaker could have tripped or a fuse could have blown. Solution: check your circuit breaker or fuse panel.
* The DIP switches inside the remote control -- which set the frequency on which the control transmits -- could have been knocked out of position accidentally or by a child playing with it. Solution: check the code on the DIP switches on the receiver in the fan -- then, make sure the remote control has its DIP switches set the exact same way.
If none of the above work, then yes -- the problem is with the receiver or the transmitter (remote). The two are typically sold as a pair, and universal replacements are available at Home Depot and Lowe's.
Hope that helps! Feel free to ask for clarification if you need it!
Jun 16, 2008 | Hunter 52" Ceiling Fan With Light And...
Hunter 20531 Vista Brushed Nickel Ceiling Fan Logo
106 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
