Magic Chef CMV1000B 1000 Watts Microwave Oven
Microwave not heating up
shared by 2 users
posted by kwon00 on Jan 03, 2008
We moved the unit to our new home, after that it stoped working (heating up food). I noticed door a little loose, Unit is a MAGIC CHEF model
"MCO153UW" I think a little old and can't find manual online.
Thanks,
Dean
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Posted by Guest on Jul 14, 2008
unit heats up okay but, fan and light do not work, after 1.5 minutes unit shuts off completely then comes back on later by itself?
Solution #1
posted on Jan 03, 2008
Not Rated (0)
sedonix
Rank:Guru Guru
Rating: 86%, 497 votes
Magnatron is suspect. Need to put a voltmeter on the input (primary) side to the high-voltage transformer (big heavy iron thing in there) Should be getting 120Vac when it goes to cook cycle. Don't touch the other (high voltage) side of this transformer. If the power is there, you are looking at replacing either the magnatron or the high-voltage capacitor and diode. Its affordable if you do it yourself - buy the part on EBAY - lookup "universal magnatron"
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Microwave not heating up:
I don't want to Accept this solution
Can you Help with these Microwave Ovens problems?
Magic Chef CMV1000B 1000 Watts Microwave...
magic chef mod no. mct9e1st micro works toaster portion...
Good evening, There is a fault code "D" on the...
This is very frustrating because this microwave is not...
I had a GE over the range microwave oven, which came with...
there is 17" clearance from top of burner (gas stove)...
Loading problems.
Repair Service
Find Microwave Oven Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Appliance Services
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
