Question about Refrigerators
Hotpoint side by side Model HSS25GFPJWW
I have a 2 yr refrigerator that makes ice, but when you push the ice dispenser the light dims and neither crushed or cube ice comes out. the water will dispense but no ice. The dim light with gradually get brighter as it would normally if it was dispensing ice. Any idea as to what the problem would be?
  • 5 more comments
  • srsjf Jan 07, 2008
    ice dispensenseing tube is clear.
  • Anonymous Jun 12, 2008
    We have the exact problem with the same model # and about the same age!. The first thing we did was check the shoot. We took the ice tray out and emptied it so it could start with a new batch of ice and that didn't work either. The ice dispenser has been broken now for 4 months or so. Now the water dispenser is starting to die too. The light gets dim and sometimes we get water and sometimes not.
  • GoingDeep Jun 18, 2008
    We have the same problem with this model...What gives? Somebody has to have this figured out...any answers?
  • jdod Jun 20, 2008
    Same - think it is the control board output.
  • Anonymous Dec 05, 2008
    my problem seems to be exactly the same as srsjf's. i don't have any noise coming from the ice maker area when i put a glass against the arm to get ice and the light dims. it makes ice fine as the compartment is full of ice and no blockages. the water works fine and the light is bright. i checked the motor area and vacuumed the area good.
  • Anonymous Jan 26, 2009
    i have the same problem...i guess these fridges are so good after all
  • maestra21 May 15, 2009
    We have the Hotpoint side by side Model HSS25GFPJWW. We have had it for 2 1/2 years. Last year the water would sometimes dispense and at other times it would not. For 3 weeks now, the ice
    will not dispense. As stated in other problems, it makes plenty of ice. We have also emptied the ice and let it start over, but it still will not dispense ice. Is the control board, listed in the solution, easy to put in or will it take a professional? Where is it located?
    THANKS!
Your problems are the power board for sure. I have the same refrigerator and have read dozens of forums and advise pages looking for answers. If you let the problem countinue your fridge will completely stop cooling and all your food will be trash as has happened to me.
Symptoms: Fan in the back starts to make click or flopping sound as it tries to start up. Ice despenser doesent despense ice. water works sometimes. Eventually you notice your food defrosting partially and then refreezing as the defrost timer stops working which is controlled by the power board. Light dims and pulses when you hold the Ice despencer in. If you remove the light for the dispencer your water will work fine as long as the fan isnt making the clicking noise. Fan will eventually start up and run.
FYI GE customer Care is useless
Posted on Nov 13, 2008
This is what I was able to find.
You need a new power board, here is the part needed...
http://www.appliancepartspros.com/part_details.aspx?part_id=3950129&pn_=WR55X10552
Posted on Oct 01, 2008
I have the problem with my water not dispensing but the ice does. What I've found works is this: Dump all ice into a container and put into freezer. Take out the icemaker and let it sit out in the sink overnight (at least 12 hours). Put it back into the freezer and then the water will dispense again. I think that the water line freezes up on it. I guess you could try the same thing for the icemaker not working. My icemaker also continues to make ice when full so I just turn it on for a day and then turn it off until I need more ice.
Posted on Jun 08, 2009
  • 26 Answers
Howabout try to check to see if something is stick in the ice dispensing shoot. This will cause nothing to dispense and will get have a dim light.
Okay, Spurs21
Posted on Jan 04, 2008
The water is not working, but ice dispenser is, the make number hss25gfpjww
Clogged water filter or faulty water valve. You have a dual water valve on that unit which explains why the ice maker is working and not the dispenser.
Feb 23, 2011 | Hotpoint HSS25GFT 25.0 Cu. Ft....
hi there
you should let an electrician have a look at that because the lights that dim only means that there is a grounded wiring somewhere inside your fridge. what you can do is just look for an open wire. thats it. apparently, you could d this yourself, but be careful. hope this helps
fixya!
Jan 31, 2008 | Refrigerators
Have a GE Fridge Hotpoint Model HSS25GFPJWW The ice make, makes ice but the water dispenser (to fill a class) doesn't work. Replaced the filter and it still doesn't work, in Oct 09 it the same thing...
i would ck the water valve . this is a dual valve in the back one side may have burned out and is not opening to let water in one side is for icemker and other for foutain . and also ck the water line inside freshfood see if its frozen. ( if themp is too cold in fresh food side it will freeze . should be about 38 deg .. hope this helps mm
Jan 20, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice Maker doesn't work
i press ice dispenser . and ice will not come out an light goses dimm please help
Sep 01, 2008 | Hotpoint HSS25GFP Side by Side...
Ice maker for Model HSS25GFPJWW
Probably, but sometimes frost builds up in them and makes them unable to turn. They are gear reduction motors so you may not be able to turn it by hand, but if you take the ice container out, hold the door open, the door switch closed and press the ice dispenser and try to turn it whichever direction it's trying to go, you may be able to free it up. If that doesn't work you'll most likely need a new auger motor.
Jul 21, 2008 | Hotpoint HSS25GFP Side by Side...
Hotpoint Ice Maker Stopped Making Ice
Friend,
ngfam1 At your service!
I came to your service on fixya.com some days ago!
And gave you some good advice!
But, I did not receive a rating from you yet!
Can you please give me a rating at our fixya.com site!
Bless, You ngafm1
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF
Jul 04, 2008 | Hotpoint HSS25GFP Side by Side...
Ice maker not working
The icemakers won't make ice if the temperature is not below a certain set point. Varies between manufacturers. Try making the temp colder.
Feb 01, 2008 | Hotpoint HSS25GFP Side by Side...
Clicking, no water or ice, power problem?
first i wold check the micro switch that the acuator paddle trips next i would replace the watervalves which is the most likely cause of this finally id replace the control bd as some early ges had a promblem with this there is also a solinoid in there for opening the ice chute door but that wouldnt affect the water but may cause a voltage drop if its getting bad id change the water valves the ice is on one valve the door water is on the other
Jan 19, 2008 | Hotpoint HSS25GFP Side by Side...
Refrigerators Logo
2,452 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
