OKI C5500n Printer
Problem for OKI C5500n Printer
The printer is on and when I send documents to
By bettylou_2 on Nov 01, 2009
The printer is on and when I send documents to the printer it says data is coming then gives me a fatal error 928 it might have to do with the paper uptake
Solution #1
posted on Nov 08, 2009
Not Rated)
Worcesterlad
Rank: Wiz
Rating: 87%, 16 votes
Error 928 is generated by the "Engine" board that controls all of the motors, clutches and sensors in the printer. It indicates a Fuser lock motor error usually caused by the Fuser or Fuser motor not rotating. First step is to remove and inspect the fuser. This is at the rear of the printer, has a blue lock lever on both sides and lifts out. Any damage to the rollers can cause it to jam or if there is a sheet of paper wrapped around a roller. be careful when removing a fuser as these can be extremely hot, follow the instructions in the documentation that came with your printer to remove the Fuser.
Was this helpful?
Yes
No
Popular Solutions for OKI C5500n Printer
Questions and Unsolved Problems for OKI C5500n Printer
Do you recommend OKI C5500n Printer?
Answer
Answer
Installed a supposedly compatible LD Printer Products toner cartiridge. Powers back up with a... (More)
Answer
fatal error message says ''231: fatal error 03''
Answer
need to down load the driver for Oki 5500 for Vista
Answer
we just bought new k toner cartridge for oki 5500 and it still gives us error with k cartridge
Answer
how do i reset drum life on oki c5500n black k drum , steps to follow
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Printers Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(918) 583-5483
Elite printer Services, Inc. is a full service HP...
Elite Printer Services
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
