Question about RCA 32F531T 32" TV
TV will not come on
Our RCA 32" tru flat will not work! You can turn the power on and the green light appears - then it immediately shuts itself off. You never get a picture or sound - just turns on and then off again. What is the problem? Can this tv be saved/fixed?
  • HBJONES8 Jan 03, 2008
    We just purchased it from a friend...I think it's only like 4-5 years old. We thought we were getting a good deal for $75 and it worked for a week and then stopped!
    I turned it on, heard the sound, walked away to let the dog in - came back through the door and it had turned itself off. Then, every time I pressed the power button - the button turned green (as if it were powering on) and then it would immediately power off - never showing a picture or sound again. I did all of this via the buttons directly on the tv (we haven't gotten the remote yet for it)
    Should I feel static in front when I try to power it on?
    Thanks so much for your help, suggestions, opinions!
  • 579 Answers
How old is this TV?
Sounds like it has high voltage failure.
(If you hold your hand on the screen when you try and turn it on, do you feel the static? )
Unless the set is over 10 years old, I would overhaul the high voltage circuit. Should cost under $200 at a shop.
Posted on Jan 03, 2008
  • Anonymous Jan 03, 2008
    Yes, When the high-voltage is working, you feel a kind of fuzzy sensation. Try it on any working standard TV.
6ya staff
SOURCE:
RCA LCD TV gets stuck on one channel
sounds like you have an intermittent defective main board. ebay rca model for replacement board.
Jan 11, 2015 | RCA Televison & Video
My rca shuts itself off after 5 mins
1 press setup / tv menu in tv mode the tv menu screen will appear
2 press the arrow up or down arrow to select setup than press enter
3 press up or down arrow to select auto-shut off and turn it off
Mar 03, 2013 | RCA L32HD32D 32 in. LCD HDTV
I have a RCA 32" Flat Screen TV that shut off and
The sound was came from the clicking of the relay. This kind of symptoms is an indication of out-of-regulation condition on the power supply section. This is caused by faulty electrolytic capacitor. It will dropped the supply voltage and will trigger that kind of symptoms.
Faulty electrolytic capacitor mostly has a physical indication of fault like bulged/dome at the top and can be easily identified. See sample picture of faulty electrolytic capacitor below.
capacitor with bulged/dome at the top.
Check these parts on the power supply section. Once found, replaced it with same capacitance and working voltage which is printed on its body itself. Click this LINK for more info regarding electrolytic capacitor.
If you don't have necessary tools and test instrument and can't troubleshoot the unit yourself, I would advice you to look for a qualified TV Technician to isolate the faulty parts.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Aug 05, 2011 | RCA L32HD31 32 in. LCD HDTV
LG 32" Plasma TV power-on problem
Your power supply board is dead, u know basic electronics’ and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
hope this helps...
Jul 02, 2010 | Panasonic TH-42PWD6UY 42 in. HD-Ready...
Rca l32wd22 blackscreen
princess_dc6,
Just recently, I was told how to get another tv.
You find a good TV service centre and ask them to fix it. If they cant you take the work order from your tv sc and call 1-877-297-8391.
You will get yourself a tv
Jun 01, 2009 | RCA L32HD31 32 in. LCD HDTV
RCA 27' tru flat sdtv- power light comes on- no display,no sound.
How do you unlock your TV from Protective Mode? There is a certain code that you need in order to unlock the Television. The technicians are saying that it went into Protective Mode, when it umplugged all by itself. I need the code so I can watch my TV again.
Nov 23, 2008 | RCA TruFlat 27F520T 27" TV
Model F27650 RCA Entertainment Series
I have a RCA Entertainment Series 32' Model Number F32650Y01E024C226E just stopped working. no picture, just a chirping loud noise that came from the back of the tv.
Any suggestions?
Jan 06, 2008 | RCA 32F531T 32" TV
Tv turns self off when turned on
I have a magnavox vhs and dvd television that started turning itself off when turned on. what could be the problem?
Nov 21, 2007 | RCA TruFlat 27F520T 27" TV
RCA 32F531T 32" TV Logo
125 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
