Question about HP LaserJet 1020 Printer
Hp1020 won't print pdf files
We have hp 1020 and it crashes the spooler system when printing pdf files.
it print everything else just fine or I can print pdf's to our network printer. had uninstalled adobe 8 and reinstalled, worked a couple of times but now is back to the same problem. I downloaded the latest drivers. no change.
I didn't have the original disk but downloaded it from the web and gonna try to use that to see if that will cure the problem..
Was wondering if you have seen this behavior and found a solution for it.
Thanks
Ted Reichelt
  • 1 more comment
  • Anonymous Jan 05, 2008
    hi i have mism problem, i consult at hp, they say that it is normal problem
    can you contact hp??
  • Anonymous Dec 08, 2008
    I have same problem, who can help!!
  • peterdmholme Feb 27, 2009
    my laptop refused to print anything after trying to print a pdf on the 1020. it lost all other printers i had loaded also. something about spooling .... i have lots of memory, laptop only 6 months old
The 1020 Has Known issues printing PDF files. The HP LJ 1020 is a HOST printer with NO SUPPORT for PS (post script) or PLC commands. Most users end up printing the PDFs as images. That was not a solution for us and we trashed our 1020 and went with another brand. Good luck.
http://forums12.itrc.hp.com/service/forums/bizsupport/questionanswer.do?threadId=1153974
Posted on Jan 25, 2008
Use foxit
or
print in image mode from adobe reader[print> advanced> select print in image mode.
Posted on Aug 29, 2012
  • 233 Answers
You can increase the memory on the printer. pdf files are basically images so it uses more memory to build on the printer before printing than a typical document.
hope this help
thanks for your rating
Posted on Jan 07, 2008
  • al hiller Aug 31, 2012
    how do you increase the memory on the printer?
No but same problem occured with pdf file , win7 ultimate. bellieve it is a pdf file made of an accountant program and probably graphical in true nature in origins, not word or similar... HP1018 and all other printers disappered, had to reload win7 from three days ago to fix problem. happened twice, then I deleted pdf.... **** happens 2 times not more.
3-1
Posted on Mar 18, 2010
To fix the Printer after a PDF screw up. Disconnect printer cord, My computer, right click, Manage, Services and applications , services, Printer Spooler, Restart the service. Go to Printer, delete print job. Plug in printer.
Posted on Mar 16, 2010
HP B8850 photo printer originally installed on an XP machine. Now running on a Win 7 unit (SP1) x64. Most printing done from Photoshop CS2. Up until a few months ago, everything ran fine on the x64 Win 7...
Try this.
Right click on the desktop and create a new Text Document, rename it spooler.bat
Be sure your computer is set to display file extensions otherwise you will end up with a file called spooler.bat.txt but the .txt will not be displayed. Right click on the file and select edit. type the following:
net stop spooler
net start spooler
Save the file.
Between print jobs, run this by right clicking on the file and Run as Administrator. Maybe restarting the spooler will work and you will not have to reboot.
Mar 07, 2017 | HP Photosmart Pro B8850 Printer
My HP1020 giving me great headache that I can see the print job pending in the printing list but no print out. Once I sent in the print job, the printer's orange light blinking and it turns to green light...
Use the Print Diagnostic Utility. You can download it for free. Please follow these steps:
- go to www.hp.com on you web browser - click support and drivers - select "download drivers and software" - type your printer's model # or name (ex. Laser Jet 1020) - click search - you should be on the window which lets you select an operating system - select your operating system and click "next" - step 2 should appear - click utility - click HP Print Diagnostic Utility - click download - run or save the file (i recommend you to save the file)
Apr 24, 2011 | HP LaserJet 1020 Printer
WHEN I GIVE A PRINT COMAND IN HP1020,IT GOES WITHOUT AN ERROR BUT DO NOT PRINT AND IT IS IN QUE WHEN I RESTART THE PRINTER NO RED LIGHT BLINKS IN THE PRINTER BUT THE GREEN LIGHT IS ON PLEASE GIVE ME...
When I try to print word file on my printer HP Laser Jet 1020 the driver of the printer is always escape. Every once in a week it is happening with me.
Plz give your best salutation to me for rectify this problem.
Thanks.
Apr 05, 2011 | HP LaserJet 1020 Printer
Pdf file won't print. printer works fine for everything else but this file won't print.
Are you getting an out of memory error?
You may have the wrong driver. If your machine does not support pdf but the driver thinks it does, it will send the file directly to the printer instead of converting it to another format.
May 20, 2010 | HP LaserJet 1020 Printer
Print spooler error
reinstal the driver with print spooler running, good luck
Apr 06, 2010 | HP LaserJet 1020 Printer
Printing problem (local and network) only with pdf
PDF files are designed to be small on the computer and are uncompressed when sent to the printer. The size of the PDF is filling up the memory on the print server causing it to crash.
make sure you have the latest printer drivers.
heres a work around if the drivers didn't fix it. check "print as an image" from within printing options in Adobe Acrobat (you gotta go to "advanced" to find that check box), and then it works fine.
Apr 06, 2010 | HP P2035N LaserJet Monochrome Printer
HP1020 printer that will not print
Is the printer connected locally to this print? If so move it to a computer that has been working ok and try it on that computer. If the problem moves with the printer then the problem is the printer not the driver or computer. If the printer is networked make sure the IP address is not the same as another devise on the network. Also print to it from another computer on the network and see if it prints.
Oct 26, 2009 | HP LaserJet 1020 Printer
Shared HP 1020 Printing problem
Your question is not clear.
Please give some configuration info. e.g
Operating system?
Explorer Version?
Jul 15, 2008 | HP LaserJet 1020 Printer
HP LaserJet 1020 Printer Logo
3,557 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
