Maytag Bravos 7.0 Cu. Ft. Electric Dryer - White
Problem for Maytag Bravos 7.0 Cu. Ft. Electric Dryer - White
Maytag bravos dryer makes loud grating sound
By tvalone on Nov 01, 2009
maytag bravos dryer makes loud grating sound
Clarification Request
Posted by mef443 on Nov 01, 2009
how old is the dryer? does it start right away? does it happen on both the automatic mode and when you set the manual timer?
Solution #1
posted on Nov 02, 2009
Not Rated)
hunter19_46m
Rank: Guru  Maytag Washers & Dryers  Expert
Rating: 91%, 433 votes
UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication.
If you have a front loading machine,
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt, remove the drum and belt and this will expose the drum rollers.
Check your rollers for flat spots, if they have flat spots on them replace them.
If they don't then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
I hope this helps
Was this helpful?
Yes
No
Popular Solutions for Maytag Bravos 7.0 Cu. Ft.
Questions and Unsolved Problems for Maytag Bravos 7.0 Cu. Ft.
Do you recommend Maytag Bravos 7.0 Cu. Ft. Electric Dryer - White?
Answer
Answer
may tag bravos will not start... lights come on... all fuses are good and door is closed firmly.. no... (More)
Answer
my door latch broke and i want to get a new part. where can i get it?
Answer
How do I reprogram the panel to factory settings and reset the sensor?
Answer
3-beeps when I hit start button , but does not start? Everything appears to be normal.
Describe your Dryers problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Dryer Experts
Top Washer & Dryer Repairmen
in , PA
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
close
Add to My Products
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
Step 1: Select a category & subcategory
Appliances Cameras Cars Computers Electronics Home Audio TV & Videos Tools
Appliances Cameras Cars Computers Electronics Home Audio TV & Video Tools
Step 2: Select a product and click on add
I can't find my product
select
Cancel
close
Success!
Add another product
Close
close
Save This Product
Enter your email address
We will not share your email. Privacy Policy
I agree to the FixYa Terms of Use
Send to friends
Send to: (e.g. Julie@email.com)
(Separate email adresses with commas)
Your name:
Your email address:
Message:
