Question about Tricity Bendix AW1000W Front Load Washer
Bendix 800 autowasher
How do i replace the bushes on the above ?
  • 54 Answers
Put it on its back on yhe top side of the motor you will see the brushes two screws hold each one on.
Posted on Feb 12, 2008
Engine start Bendix still engaged put into any gear Bendix disengages can go back to park there will be no more problem
if your saying your starter stays engaged after starting engine till you cycle thru the gears , your starter needs serviced , most likely a worn bendix pivot bushing
two options 4 repair
1= replace starter
2= remove starter and have it professionally rebuilt then reinstall it
Sep 14, 2015 | Cars & Trucks
Bendix 800 autowasher de luxe, drum spin snagged then cleared.
should b nothing off this description on ure machine unless the pump coil has over heated iff so just replace coil and check for blockages
Jul 13, 2009 | Tricity Bendix AW1000W Front Load Washer
Is my bendixx 1000 autowasher hot or cold fill
Look at the top left rear of the cabinet, there you will see the connections for the inlet valve(s), if there is only 1 then it is a cold fill only, if there are 2 connections , then it is hot and cold fill.
They are normally marked H and C.
Plz leave feedback for this solution.
Dec 17, 2008 | Tricity Bendix WDR1040W Front Load Washer...
if not starting at all, fault is probably the door interlock - easy to replace.
disconnect from mains.
prise off the plastic clamp holding door seal to cabinet and peel back the seal in the area of the door interlock.
interlock is held by 2 screws from the outside and remove these so interlock comes away. remove electrical plug and socket connection and remove the small diameter hose at the bottom of the interlock. interlock can now be removed completely.
refitting is just the reverse.
Nov 10, 2008 | Washing Machines
Ford Escort 1.6Gl Automatic '78 starter
i had the same problem and a auto told me the starter is running the wrong way then he changed the field by turning the brushes around hope it works for urs
Aug 01, 2008 | 1983 Ford Escort Gt
I have a Bendix Autowasher 800 washig machine. The door lock seems to have broken, with a load inside the machine, and I can't open it to get the load out. The cycle has finished. I think I broke it by...
Have the same problem myself.
Remove top panel from washing machine by undoing two fixing screws to rear and sliding panel forward to front of machine.
Door lock is located internally on right hand side, its difficult to reach and I had to loosen the control dial and switches to gain access.
However it may be possible to release the mechanism by touch.
At the back of the lock mechanism the latch protrudes by approx 3 mm if you can see it or feel it you only have to apply some pressure to the projecting end to release the latch.
The broken release lever can then be removed from the door and replaced by a new part which cost about €6.
Jun 29, 2008 | Washing Machines
Tricity Bendix AW1000W Front Load Washer Logo
356 people viewed this question
Top Tricity Bendix Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you a Tricity Bendix Washing Machine Expert? Answer questions, earn points and help others
