I have an Intermittent fault with braun 18" dishwasher, it fills with water the control panel lights up it then chugs away for a few minutes and then just cuts out, lies dead for a bit and then bingo comes to life again. I have no idea how long this has been going on as only noticed it over xmas break. It can take 5 hours to complete a cycle.
-   My Bosch Excell AUTO OPTION model # SGS43E08GB/35
Has exactly the same problem, i have taken it apart at the front and got it to work for one cycle, messed around with the door lock (now broken lol) so i know i need a new one of them, but when this was broken i held the on/off switch in and it worked, but then cut out even though the micro switch was in the right position, and i was holding the on/off switch in still....do you think the problem lies in the on /off switch, or + micro switch or further towards the control module? am i going to be wasting my money !!! please, any info would be superb cheers Darren.-   DazTuz
check this out. I suspect loose connection on relay pin at back of pcb. Try tapping near the buttons and see if you can re-start it even for a second. This is how i isolated problem to the pcbs in the control unit. I have the loose pin with solder blown off - I just need a new soldering iron to fix it. If you not able to tackle yourself, qer.biz will do it for you, or replace with a reconditioned board for reasonable charge.
we have got a bosch kitchen controller y p rm5 4XB. The hot water supply has suddenly stopeed and...
(More)
we have got a bosch kitchen controller y p rm5 4XB. The hot water supply has suddenly stopeed and its displaying -''14'' on the screen. who should we contact. Thanks, Zack.
Hello, this has never happened until after a new sink was installed with a different configuration...
(More)
Hello, this has never happened until after a new sink was installed with a different configuration of the dishwasher connect. Is this the problem? I've run the dishwasher to drain but it keeps coming back.
As I made a reset the other motor drains the water thatI put in manually . How to open the unit to...
(More)
As I made a reset the other motor drains the water thatI put in manually . How to open the unit to check the motor ?
Hi, Having an issue with my dishwasher. Some water is still left in the dishwasher after teh cycle...
(More)
Hi, Having an issue with my dishwasher. Some water is still left in the dishwasher after teh cycle is done. Can you please help me troubleshoot this issue? Tell me some potential causes for this and what I can do to fix the dishwasher? Can you please also send me a schematic for this dishwasher? Thank you, John Linta (586) 739-3637
how do you remove the two side plates and drawer. I have undone the screws but I can not slide the unit out. The dishwasher has a blockage and I am trying to clear it.
Does anyone know where I can obtain a service/repair manual and schematic wiring diagrams for this...
(More)
Does anyone know where I can obtain a service/repair manual and schematic wiring diagrams for this m/c Thanks
