Home | Toshiba | 55H70 55 in. Rear Projection Television | Watching tv and it jus...
Toshiba 55H70 55 in. Rear Projection Television
Problem for Toshiba 55H70 55 in. Rear Projection Television
Watching tv and it just quit working. power
By dclickn on Nov 01, 2009
Watching tv and it just quit working. power indicator flashes but no picture or sound. Came on for a second but went back out
Solution #1
posted on Nov 02, 2009
Not Rated)
henlopen
Rank: Wiz
Rating: 84%, 649 votes
Assuming no fuses are blown, you could have a shorted power transistor. Q801 would be the most likely from the information submitted. If a fuse is blown, there are several other possibilities.
It will take a repairman to find and replace the part(s) however.
Was this helpful?
Yes
No
Solution #2
posted on Nov 01, 2009
Not Rated)
freetek
Rank: Wiz  Televisions & Videos  Expert
Rating: 85%, 1757 votes
Typical behavior for a failed main power supply. These are probably not built or repaired by Toshiba since this kind of subassembly is normally bought from other specialized manufacturers.
My suggested 'fix' is pasted below-
If it's failing to turn on, the main power supply is probably at fault and without some technical background and a couple of test instruments, you will not be able to do the repair yourself.
What you can do though is; unplug the set, let it stand overnight or at least several hours, remove the back panel and look for a separate board with mostly larger components on it; it will have a ferrite core (no laminations as with a line-frequency part) transformer on it and several larger capacitors which are cylindrical and mounted vertically to the board.
Before touching anything inside, especially on that board, allow several hours to be safe since the larger capacitors can hold a painful voltage charge for some hours.
If you see signs of overheating such as discoloration of the board material, the PSU may not be repairable but if you can find a part number on the board, you might be able to buy the power supply from the mfr. and install it yourself but it will likely have the same problem eventually unless they have altered the design or improved component quality.
If there are no signs of heat damage to the board, there may be companies offering to repair it as a subassembly instead of repairing the whole set which could be much more expensive.
If you choose to replace or have it done, the main power supply still may not be at fault since most are capable of switching on and off if a downstream problem is causing an overload.
Was this helpful?
Yes
No
Popular Solutions for Toshiba 55H70 55 in. Rear
Questions and Unsolved Problems for Toshiba 55H70 55 in. Rear
Do you recommend Toshiba 55H70 55 in. Rear Projection Television?
Answer
Answer
the color on peoples faces is pink. It seems as though the green tint is gone
Answer
the color tint is like pink on peop[les faces and it used to go to the correct color after it was on... (More)
Answer
How do you remove the front panel of our 55" Toshiba for cleaning
Answer
My tv is a Toshiba 55H71 but this is the closest number i found to it. We are having problems with... (More)
Answer
TV was flooded. Already cleaned and ready for re-assembly. We need a circuit diagram to check... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Toshiba 55H70 55 in. Rear...:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 689
Experience: 30 Years of professional repair and design.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
