Problem in hard disks
If a hard disk is damaged and has outed from work can we repair it?
If your answer is yes How we can make it workable?
sorry I dont know English completely but I hope you have known my purpose.
Naseer Ahmad
Afghanistan
    Scholar:
  • 131 Answers
You cannot repair the hard disk. But if the data on the disk is very very important, you try to recover the data from the hard disk, this recovery is not hundred percent.
Posted on Jan 03, 2008
My Dell Dimension 2400 refuses to load Windows XP
What happens?Does it hang on the loading page or does it restart itself before loading?
If it hangs on the loading page,press CTRL,ALT and DEL.This boots the system.
If it restarts itself,remove the hard disk and re-fix it again.Problem solved?
Remove the CMOS battery and the hard disk and re-fix them again.Problem solved?
If not,you may have to repair your operating system.
This how you do it:-
  • Remove your hard disk and enslave[fix it as a secondary drive] it on another machine with a good operating system.
  • Start the machine.Accept to run unnix[using two drives]
  • The machine will automatically detect your hard disk's failure on the operating system and repair the damaged files.
  • On completion and after Windows opens,turn off the machine and remove your hard disk.
  • Fix the hard disk now on your machine and start it.
Hope this helps.Thanks!
Please rate this answer.
Oct 31, 2011 | Dell Dimension 2400 PC Desktop
Tip
I have tested several programs, but the program below, just really worked for...
Let's try to explain the question that grinds us all when in cams about the hard disk. Can we actually repair a bad block? Before of the answer you must find some information about what is a hard disk, how does it work, what are bad blocks. After that you must identify them because you will need the exact location of the affected sectors. After you have done that you must run a few steps:
- before you try to resolve the problem with the bad sector you must extract the data that was written to that block. To do this you must run a Recovery program that you can find freeware on the net.
- bad sectors are unreadable parts on your hard disk but the nature of them must not be always physically and that part of the platens to be destroyed. The bad sectors can be simulated by some programs. This means that some programs installed on your computer can interrupt the reading process on to another segment of the platens. That is in the most happier cases but the chances that the bad sectors are cause by this is less then 10 percent. In this case is difficult to resolve the problem because even the Scandisk or other identification programs used to discover bad blocks will give a rapport that nothing is wrong with your hard disk. The best way is to uninstall the latest programs applied to the computer.
- lets supposed that you have a 20 gigabits partition on your hard disk that has bad blocks. After the identification program it will indicate you where are the blocks situated on the partition. So this way you can isolate them in to another partition that you must never use again. Another scenario can be created and the bad sectors can be at the beginning of the partition in the middle of it and at the end of the partition. Know it's a little bit tricky because you can't just go on and create three new partitions to eliminate the bad sectors from use. In this case most of the new hard disk has a spare space available just for this type of scenarios. You must access the CASH memory of the hard disk and indicates to the hard disk that instead of writing down on the effected blocks it must write to the spare blocks.
- another to restore the hard disk is to use the low level format option. Many of you think that low level format is a program. Wrong, the low level format option is set for any BIOS and can be easily use if you know some command line programming. The low level format can take to be complete a very long period of time but in the most cases we can obtain marvelous results. Actually the low level option takes every cluster of the hard disk and identifies them again (throw a thermal process) and writes down on the memory of the hard disk what sectors can be written and witch blocks are un-writable. This procedure is the best that can be because it will need no effort from your side to try and avoid the bad blocks that already exists and the hard disk itself know where the bad blocks are.
In conclusion the bad blocks can't be fixed. The problem is a permanent one and we can only try to use the hard disk until it is broken down for good. But if you are having financial problem this is a best way to keep going with your old hard disk.
on Mar 12, 2011 | Computers & Internet
Lacie Biggest s2s 2.5TB eSata RAID having trouble mounting. It comes up some times, but most of the time it does not mount. I was working with it in Snow Leopard, but got an error message at startup to...
It is time to check the WARRANTY status of the disk-drive.
If the warranty has not yet expired, exercise the warranty, to get it repaired/replaced, at minimal cost to you.
Otherwise, open the case, remove the "dying" disk-drive, buy a new, compatible, disk-drive, and "transplant" it into the case, to create a working external storage device.
Jan 21, 2011 | LaCie Biggest S2S (301050) 500 GB Hard...
Hitachi hard disk model no. Dk23ba-20 crached. it isnot working. is theire any way to make it workable.
It depends on your definition of "crashed" -- if it still spins and works, but the copy of Windows stored on the disk no longer successfully boots into Windows, that's one type of "crash",
and you can recover (by reinstalling Windows).
If it does not spin, or nothing can be read from the disk, that's another type of "crash",
and it's usually a "fatal" problem -- the hardware will never work again.
However, there exist professional "data recovery" services, that can repair your disk-drive,
just long-enough to _once_ read your files and copy them to a new disk-drive.
Example: http://www.seagate.com has "no-charge-if-we-cannot-recover-your-files".
Nov 06, 2010 | Hitachi (DK23BA-20) 20 GB Hard Drive
My IBM Thinkpad R40 laptop stopped working.The IBM Think Pad screen comes up and then with a beep,the system shuts down.Went to a support shop and found some IC on the system board was damaged.Now,for data...
Unless the hard disk itself is damaged, data should be perfectly recoverable. This does not mean that any USB device will be able to read the unit. Some external attachments I found were not capable of reading large disks, or required those disks to be formatted while in the attachment, meaning that the disk addressing mode wasn't autodetected at all.
On the other hand, the disk MIGHT be damaged. Sorry to mention it but it's a possibility. Were those damaged IC on the board connected to the disk I/O system? (Or, maybe, the ICs only seemed to be damaged, but were actually working - it was the HD which was damaged all the time, and the system rebooted as soon as it tried to access the disk).
I'd suggest having the disk connected with a 2.5"-to-3.5" adapter to a Linux machine as secondary hard disk. This will allow direct talk to the disk unit, bypassing external devices and the like, and allowing direct access to the partition, with a much more informative error logging than Windows systems are generally equipped with.
Nov 03, 2009 | IBM ThinkPad R40 2897 Notebook
WD HD Media player damaged my hard drive??
Hi Dear! This problem could be solved through a software. You should use Western Digital Disk Manager, your WD hard disk will work properly after using that your WD hard disk pass all test of the software. When it will pass all test it will work properly and in other condition if it will not pass then you should try again so that the software will fix the error and it will made workable.
Thank You
Jul 24, 2009 | Western Digital My Book Premium ES...
Hard disk repair
is it an external hard disk and does it get detected by windows.. if so try chkdsk /f on the disk.
Aug 31, 2008 | Seagate (9W2041-337) 40 GB Hard Drive
Bad sectors
Use the following link to download the software, which helps u to detect as well as completly remove badsectors, but before u do tat, here is the answer for wat is bad sectors..
Hard disk drive is an integral part of every computer. It stores all your information. One of the most prevalent defects of hard drives is bad sectors on the disk surface. Bad sectors are a part of the disk surface which contains not readable, but frequently necessary information. As a result of bad sectors you may have difficulties to read and copy data from your disk, your operating system becomes unstable and finally your computer may unable to boot altogether.
When a hard drive is damaged with bad sectors, the disk not only becomes unfit for use, but also you risk losing information stored on it. The HDD Regenerator can repair damaged hard disks without affecting or changing existing data. As a result, previously unreadable and inaccessible information is restored.
ths is the software
A powerful hard disk tool that can detect and repair physical bad sectors on a hard disk drive surface and regenerate hard disk.
http://www.4shared.com/file/49739096/5f24d2c2/HDD_Regenerator_151_Full.html?s=1
Jul 17, 2008 | Microsoft Windows Server Standard 2003 for...
Hard disk
your seagate is absolutely damage. replace hard disk instead. maybe some repair shop can repair hard disk. Just try ok.
Dec 26, 2007 | Iomega MiniMax (33464) 250 GB Hard Drive
Computers & Internet Logo
66 people viewed this question
David Payne
David Payne
