Question about JVC GZ-MG130U Camcorder
Power problem The camera only has power when plugged into the ac adapter. When unplugged it loses power and immediately. Any ideas? Rick
  • Anonymous Aug 04, 2008
    My camcorder will not turn on. Even when plugged in.
  • Anonymous Dec 19, 2008
    same problem...
    first, difficulty loading video onto my Mac.
    On my second try the camcorder battery ran out of power.
    Third try, I plugged it into a power outlet and was successful.
    I then left the battery to charge, however when I unplug, nothing.
    Dead battery.
  • 21 Answers
Your battery is probabily uncharged or disconnected. Try taking the battery out and putting it back in. Then charge it (by plugging in the AC adapter) until the green activity light stops flashing. If this does not work, your battery is probabily dead. Did you short it out? Or perhaps it is old. Li-Ion batteries (the kind used in these machines) lose their ability to hold their charge in a few years - even if they're not in use! So, if your battery is 3 or more years old, try considering a new battery.
Posted on Jan 29, 2008
You must turn off power on camera while charging
Posted on Nov 10, 2008
I HAVE THE SAME CAMCORDER AN D I BOUGHT A BN-VF823U BATTERY MADE BY POWER2000 AND THIS WILL GIVE YOU ABOUT 5 HOURS, ALSO YOU CAN BUY A BATTERY CHARGER THIS WILL CHARGE ALOT FASTER FROM THE AC ADAPTER
http://www.snapitdigital.com/itemdetail.asp?mod=POBNVF823KIT
Posted on Aug 03, 2008
What is wrong when AC Adapter is beeping continuously, and does not recharge laptop battery?
The adapter's Syscon detects a short circuit. It might be within the adapter itself; or with your system. Contact the authorized service centre in this case. If you have an other adapter, load it with. By this way, you can get an idea about the faulty unit. Electro help
Nov 29, 2014 | Computers & Internet
Nc6000 multibay battery does not recharge
Perhaps remove the multi-bay battery, and let main battery charge all the way. Then reattach multi-bay battery, and see if it's recognized.
(Will charge)
That is AC adapter (Charger) removed, then remove multi-bay battery.
Plug AC adapter back into laptop, THEN plug AC adapter into power.
[You do Not want to unplug an AC adapter from a laptop, with the AC adapter plugged into power. Could be a power surge/voltage spike. Unplug AC adapter from power, when plugging into laptop, or unplugging from laptop ]
Main battery charged, unplug power to AC adapter, unplug AC adapter from laptop. Plug multi-bay battery in, then AC adapter.
(Then plug AC adapter into power)
Post back in a Comment.
Regards,
joecoolvette
Feb 28, 2013 | HP Computers & Internet
The toshiba laptop a505 S6980 will not charge the battery when the AC is plugged in and dies immediately if unplugged . Meters shows 0% available (plugged in), charging. But it is not really charging.
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Apr 20, 2011 | Toshiba Satellite L500-ST2521 Laptop AC...
Power problem
Here are some ideas you can try when troubleshooting power issues with a laptop:
1. Plug the laptop into AC power.
2. Take out the battery.
3. Try a different outlet.
4. Look for the light that indicates that the AC adapter is plugged in. If that light isn't on, try plugging and unplugging the AC power jack and moving it around until the light shows its connected. If no light comes on, its possible you have a bad DC jack or the AC adapter needs to be replaced.
5. If the indicator light is on and the laptop won't power on, then it's possible you have a bad switch board or stuck button. Make sure no buttons are stuck. Conversely, push hard on the power button and move it around in order to make sure you're making good contact.
6. If you know the battery has a charge, unplug the AC adapter and connect the battery. If it turns on then you can be sure you have a bad DC jack or a bad AC adapter.
7. Replace the switch board and/or the flex flat cable that runs from the switch board to the mainboard.
8. If your laptop has another button that turns it on, such as an internet button, try that button instead of the normal power button.
Hope one of these ideas helps.
Thanks for using FixYa.
Mar 03, 2011 | Computers & Internet
I was just kind of chilling on my laptop most of the day. And it kept like running outta battery like it normally kinda does every now and again. I kept it plugged in most of the day but it wouldn't...
Make sure the ac adapter is correctly plugged into the notebook and into the power cord.
If everything is plugged in correctly and it still will not power on, follow these steps to complete a 'power reset' of the notebook.
  1. Unplug the ac adapter. Keep ac adapter unplugged.
  2. Remove the battery and keep the battery unplugged.
  3. Hold the power button down for 15-20 seconds. (Nothing will appear on the display and none of the lights will light up.)
  4. Release the power button and plug in the ac adapter ONLY. (Please note that a power indicator light should be lit on the ac adapter when it is plugged in).
  5. Normally power on the notebook.
  6. If the unit does not power on, remove the ac adapter and insert the battery into the system.
  7. Plug the ac adapter back into the system, the battery charging indicator light will light up.
    If the battery charging indicator light does not light up, the ac adapter may not be providing proper power to the unit, and may need to be replaced.
Dec 28, 2010 | Computers & Internet
Battery won't charge
If the battery is not charging, then the charging circuit of the motherboard is bad.
Page 3-22 lists the spare part number for the motherboard. (4 versions depending on options)
Chapter 5 covers disassembly and reassembly
http://www.hp.com/ctg/Manual/c00212209.pdf
May 21, 2008 | Compaq Presario R3000 Notebook
Sony dcr-dvd101 won't Power On
hi
i think that your problem is in fuses
u must open it and replace the fuses u will find a diagram inside your camcorder to locate this fuses.
u can remove them and bypass.
bye
Jan 09, 2008 | Toshiba Sony DCRDVD101
JVC GZ-MG130U Camcorder Logo
338 people viewed this question
Top JVC Video Cameras Experts
Steven Wander
Steven Wander
Marvin
Marvin
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
