dpelrod727, Yes, the "switch-mode-power-supply" is in "partial" or "full" SHUTDOWN mode. Reconnect E172FP to a fully booted KNOWN good PC with the win-desktop as the displayed screen. Check with flashlight to see if your LCD panel is both BLACK and BLANK, or just BLACK by holding a bright flashlight 1" from screen at different angles even though the screen appears to be blank. If very faint image of desktop is seen then your SMPS is still half alive. Here are your options in either case. 1. Trade in for new. 2. Try Dell for a cash+old swapout for a Refurbed unit. 3. Check out www.ccl-la.com/badcaps, www.badcaps.net, www.lcdparts.net, and YOUTUBE long video clips dealing with LCD monitor disassembly and LCD repair. could be helpful in making decision on what to do. I'm 12fixlouie If this was helpful rate on fixya.
it works when plugged directly into my laptop but can't be set as primary monitor only extension of...
(More)
it works when plugged directly into my laptop but can't be set as primary monitor only extension of laptop monitor. Get "Cannot display this video mode" message when plugged into my docking station. It used to work before I got a bigger monitor, trying to go back but isn't working. Help????
I have a delll E172fpb monitor that only displays a solid white screen is there a solution to the...
(More)
I have a delll E172fpb monitor that only displays a solid white screen is there a solution to the problem
I have a Dell flat screen monitor, model E172FPB that has started displaying the Dell monitor menu...
(More)
I have a Dell flat screen monitor, model E172FPB that has started displaying the Dell monitor menu on a frequent basis! It also displays an illustration of a padlock! Why is this happening? This just started this morning for no reason as nothing has been changed on the computer or monitor. Thank you
All functions work, but there is a graphic pciture of a lock right i nthe center of the screen and...
(More)
All functions work, but there is a graphic pciture of a lock right i nthe center of the screen and it flashes off, then stays for for about 3 or 4 seconds, then goes off and keeps recycling. What can i do to get rid of it?
